I'm new here....I'm working on a 82 XJ1100. I don'y know the whole story about what happened, the problem is the starter spinns the clutch only. if it is gear it will move the whole bike. could it be the sprag gear has gone bad? Thank for any info
cheers Jim
cheers Jim
You can take the right ALT cover off, and spin the engine via the ALT nut/bolt....it turns Counter-clockwise from that right side, don't try turning it using the square nut type fitting of the left side timing plate, it's not very strong!! I'm assuming you have the clutch cover OFF, or you're looking thru the oil fillter opening to see the cutch basket turning??? With it in neutral, you should see the clutch basket spinning when you turn the engine by hand...remove the spark plugs to make this easier, and IF the clutch isn't spinning, that will pretty much confirm the Hy-Vo chain as the likely culprit.
