Valves or Guides
  • jfmerk
    • Jul 2004
    • 120
    • Woodbury, MN
    Valves or Guides
    Hello again!
    I am back into restoring my 78 E with renewed vigor and excited to make a great deal of progress this summer with my goal of creating a bike that looks just like the one on the XS11 home page!!! In my last post... almost 4 years ago! I mentioned that my engine was torn down and in need of some valve work. I've dug out all the parts from storage and I have the head at a very reputable engine shop and they tell me the exhaust guides should be replaced. The exhaust valves did feel very much more loose in the guides than the intake valves did. The seats and valves are pitted pretty bad too. The shop indicated the new guides are on back order for "who knows how long" and if I can find my own they'd install them for me. As I look for exhaust valve guides, I am finding 1st oversize only. Is this typical? This means I would need to buy OS valves too right? Should I be looking for OS valves and just have the existing guides reamed?
    Looking forward to more discussion and sharing my progress!
    '78 XS1100E
    '83 XVZ12
  • b.walker5
    • Feb 2009
    • 1745
    • Invercargill, New Zealand
    4 years between posts.., man, you really think about things before you reply don't you. Good to have you back. I wasnt aware there was an oversize in valve guides and it doesn't make sense to me that there would be. Surely an oversize guide would be only bigger on the OD and would require reaming out the head, because why would anyone buy guides with a larger ID when all that would be needed is a ream out of the existing guides. I might be wrong though.
    • jfmerk
      • Jul 2004
      • 120
      • Woodbury, MN
      After reading through my service manual, I think that in the case of valve guides, an oversize valve guide actually means a valve guide that is slightly smaller than 7mm and must be reamed to fit the existing valves.
      Can anyone confirm that?
      '78 XS1100E
      '83 XVZ12
      • Bigleo
        • 93
        • Surrey BC Canada
        guides
        Hi, I went through this recently. I bought the oversize valve guides and measured them. The oversize was on the outside diameter. I'm guessing they were designed this way to allow for metal being scraped out of the head when the old guides are pressed out.
        Leo
        1980 XS1100 Special
        1197cc Wiseco kit
        1978 cams
        4 into 1 Jardine with glasspack
        Keihin CR33 mm carbs
        K&N individual pod filters
        TKAT fork brace
        • xssidecar
          • 20
          • NewZealand
          Hi all.I hope I'm in the right area for posting this question.Anyhow I have a problem with my 1980 XS1100g in that I have bent inlet valves from a broken tensioner guide.All fixable but living in NZ nothing seems to exist here for XS's.Having scoured the net I just cannot find any suppliers for such things as valves and guides.Can anyone help with any names please.
          Thanks a bunch.
          1980 XS1100g with sidecar
          1977 BMW R100/7
          1951 BSA A7 500cc Plunger
          2001 Kawasaki KLR250
          • Yard Dogg
            • Mar 2010
            • 884
            • Tri-Cities, Wa
            Maybe someone on here has a good head they can sell you. May be cheaper than a machine shop and parts.
              • 8962
              Here is a supplier for valves for the XS1100 engine, they are in the USA, scroll down to bottom of the page....
              • MPittma100
                • Aug 2011
                • 2359
                Valve guides
                I am wondering if the machine shop can put in the thin-walled bronze (automotive) guides. These would fit inside the existing worn guides.
                I know that replacing guides in an aluminum head is pretty tricky as normally the head has to be heated to properly release the old and install the new guides.
                I have had worn (bronze) guides repaired using the thin-walled guides because the factory guides were too hard to remove.
                May ask your machinist about this.
                I have 4 new Yamaha intake valves (3H7-12111-01) in the factory packaging if you are interested.
                MP
                1981 XS1100H Venturer
                K&N Air Filter
                ACCT
                Custom Paint by Deitz
                Geezer Rectifier/Regulator
                Stebel Nautilus Horn
                EBC Front Rotors
                Limie Accent Moves On In 2015
                Mike
                • Yard Dogg
                  • Mar 2010
                  • 884
                  • Tri-Cities, Wa
                  I don't know how hard these are, but I've heard of people using dry ice to remove them. Just take a small piece of it and set it on the guide,then tap it out. To put them in, you would cool the new guide in the freezer, then heat your head in the oven a few hundred degrees. I know it works with cast iron, not sure if it would hurt the aluminum.
