do i need a special tool?
  • scalded dog
    • 458
    Have a midnight special, 81, motor is shot, not much left on it, but was trying to save the pick-up coils, the clymer manual calls for "two screws" to be removed, it don't have screws it has what looks like a nut inside an aluminum housing, 4mm or 4.5 dosn't work, and they were the closest size I had, just wondered if it takes a special tool. Thanks, 'Dog
    You have to drill the heads out. Yamaha used tamper proof bolts on the 80 and up motors so the timing couldn't be altered (EPA).
    • petejw
      • 2269
      • sydney australia
      Theres also 3 screws that hold the assembly
      in, you can remove these 3 screws and the guts of it
      will come away.
      pete
      new owner of
      08 gen2 hayabusa
      former owner
      1981 xs1100 RH (aus) (5N5)
      zrx carbs
      18mm float height
      145 main jets
      38 pilots
      • scalded dog
        • 458
        Thanks for the replys, I spent about an hour trying different things, to get them loose. LOL. Now I know what to do. Later 'Dog
