New guy - pic heavy post
    • 6765
    Originally posted by Fix
    I would jinx myself by saying he didn't seem like that type of guy, but I'm not THAT type of guy.
    Thanks guys.
    By the way, is it normal for the bike to be calling me out to the garage at 11pm at night? I can hear it whispering to come and tinker...
    must
    resist
    Now that sounds like the mark of a true XSive! Welcome to Ch11. That bike looks to be pretty good and with some TLC and elbow grease it will be a keeper for many years...I have a keeper...had it since new too!
    2005 Honda SilverWing 600
    2018 Honda PC-Xpress 150
    • tarzan
      • 1700
      • Chandler,Az.
      Jets should have the # stamped on 'em in tiny numbers.
      And yea its perfectly normal for a bike to call your name all hours of the day and night,at least at my house.
      80 SG XS1100
      14 Victory Cross Country
      • tw1980
        • Apr 2009
        • 662
        • Bend OR
        If it has been sitting for a while,replace the gas in the tank if you haven't already done so.I've spent a lot of time working on bikes,generators,lawnmowers etc...That only had bad gas. Terry
        PS Welcome to ch 11
        1980 special (Phyllis)
          Hello all
          Hello, Fix! Welcome!
          There is a known problem area on your bike at the number four exhaust flange. The upper flange nut is missing.
          Throwing myself on the mercy of your collective knowledge, what should I check right away that are known problem areas?
          Nice find; nice bike!
          Regards,
          Scott
          • Fix
            • May 2009
            • 384
            • Lake Orion, MI
            Regards,
            Scott
            I'll be damned, good eye! I didn't spot that at all.
            Mike C
            Lake Orion, Michigan
            '78 XS1100E
            Here I am! Where are you?
            • Wildkat
              XS Special Gurette
              • Apr 2004
              • 3416
              • Location, Location
              Nice looking bike
              Welcome to the board!
              It would be abnormal if it didn't... and if you don't answer while it whispers... it'll start screaming...
              81 SH Something Special
              79 SF MEAUQABEAUXS
              81SH Nor'eas tah (Old Red)
              80 LG Black Magic
              78 E Standard Practice
              James 3:17
              “Alis Volat Propriis”
              Yamaha XS 1100 Classic
              For those on FB
              • ossjughead
                • 203
                • Ottawa, ON
                It dosent look like that anymore LOL Welcome to the forums tyhis is the best place to be for the true XS XJ guy
                http://i69.photobucket.com/albums/i7...all2008017.jpg
                • Fix
                  • May 2009
                  • 384
                  • Lake Orion, MI
                  I've checked the boards and don't see this info, but does anyone know of some throwover bags that will fit this bike? Or what I should look for while shopping for bags? Also, I'm going to need a windscreen. That little sport fairing might have worked for the PO, but I'm 6'4" and it doesn't do me a spot of good.
                  Update on the bike, it was chilly this morning, ran the choke out to 2nd setting to keep her idle, but she didn't give me any problems on the way to work.
                  Mike C
                  '78 XS1100E
                    If you are nto already, definitely get some Seafoam to run through the carbs!!
                    Should not need the choke after she warms up. Mine runs fine without it when its 40 degrees out after it gets warmed up, or about two miles or so of riding. Sounds like it sat enough to gumm up some of the carb circuits. The Seafoam might cure it without pulling the carbs. It would be recommended to pull them and clean them, but if you would prefer to ride it for now, Seafoam for sure!!
                    • Fix
                      • May 2009
                      • 384
                      • Lake Orion, MI
                      Going to grab that Seafoam at lunch today. Then I can let her sit over night with it. Thanks! I noticed that Seafoam can be added to the engine oil as well, do you recommend that?
                      Mike C
                      '78 XS1100E
                        Seafoam is alot like Gasoline (which is why you can add it to your gas...convenient huh!) which is NOT good for engine oil application. If your oil looks like crap or oyu had valve issues or somethign like that, then it has been suggested before to add it to your oil, let he bike IDLE ONLY, NO LOAD for about 15-20 minutes IIRC and then drain it and the oil out.
                        Seafoam and gasoline dilute or thin the oil out and it does not protect the brearings and such properly and can cause bad engine wear and ruin bearings and such. At least that is what I have read here on XS11. Thank goodness I have no real expereince with that!!
                        • Fix
                          • May 2009
                          • 384
                          • Lake Orion, MI
                          Good looking out! Oil was fine, so I'll let that sleeping dog lie. Checked with Autozone up the street and they set a bottle of seafoam aside for me.
                          Mike C
                          '78 XS1100E
                          • scalded dog
                            • 458
                            My first xs was a 78 standard, didn't know about this site, loved the bike, but didn't know to check for gas in the crankcase, burnt the bearings up, the way to check it is listed here but just take a green small limb off a tree, put it down inside where the oil goes, and get some oil on the stick, stick a lighter to it, if it burns you have gas in the oil, if not then you're ok for now, but will need to put an inline cutoff on your fuel lines running to the petcocks. Later 'Dog
                            • Fix
                              • May 2009
                              • 384
                              • Lake Orion, MI
                              Thanks for the tip, I'll check that tomorrow. Is the procedure to install that cutoff on the site?
                              Mike C
                              '78 XS1100E
                              • The Lorax
                                • Jun 2005
                                • 1048
                                • Riverside, OH
                                Welcome to the site, Good looking bike (looks a damn site better than mine does anyway) I second the seafoam treatment, run it through the fuel system, it's great stuff, cleans things out well. again, welcome. have a nice day and ride safe
                                I am the Lorax, I speak for the Trees
                                '80 XS1100 SG (It's Evil, Wicked, Mean & Nasty)
                                '79 XS1100 F R (IL Barrachino)
                                '00 Suzuki Intruder 1400 (La Soccola)
                                '77 KZ400s (La Putana)
