killer varnish remover
  • Filter
  • killer varnish remover
    Just wanted to let you people know that Yamalube has the best varnish remover ever.It's called carburetor cleaner dip.This stuff works awesome.Cost about 12.00 bucks and you dilute it with water.Pick it up at your local yamaha dealer. Every garage should have it.
  • #2
    It's good stuff, but you can sit back and watch it eat the seals for the throttle shafts, and choke piston unless it is formulated to be safe for rubber.
    • #3
      You know the guy at the dealer said it wont chew up the seals if you dilute it like it says to.I cleaned my carbs with it the other day and worked fine.I put 50 or more miles on her today and she did not complain.
