Charging problem
  • Bigfoot
    XS-XJ GURU
    • Sep 2005
    • 1422
    • Kansas City, Missouri
    Charging problem
    Rode the midnight special all over town yesterday and then down to Russ79's last night to sync the carbs. On the way home the battery warning light came on and the battery drained. I made it about a mile from my house. I had SWMBO bring my a battery and got it home. Would have made it if it hadn't been for stoplights. The ground cable for the battery broke off when I went to change the battery so it must have been pretty shoddy to begin with. I replaced the cable this morning and now everything seems ok. No warning light.
    Would a bad ground connection cause the battery not to charge? The cable was not completely broken until I went to change the battery. And if someone could tell me how to check and see how much juice I am getting from the charging circuit I would appreciate it. Sorry, I am a little bit of an electrical idiot.
    Harry
    '79 Standard
    '82 XJ1100
    '84 FJ1100
    Acta Non Verba
    Bummer but nice fix, Harry!
    Quick and dirty charging system test: start the bike and look at the headlight or it's reflection on a wall while you rev the engine up around 3,000 RPM. It should get noticably brighter. If it stays dull or the increase in brightness is more "meh" than "max!" you need to get out the multimeter and start testing components and connections.
    Regards,
    Scott
    • lvrsnr
      • 114
      • Kelso, Washington
      yes a bad ground would do that, and it would never have broken if it was'nt in bad shape, to verify your charging system hook a volt meter up to your battery note the voltage, then start the motor the voltage should increase to 13 to 14 volts with the motor reved to 3500 RPM...if you don,t have a volt meter you can use the hillbilly method of shining the head light on something with the motor idling, rev the motor and the light will get briter
      Alias Larry R in Kelso WA
      When in dought, punch it.
      XS1100LG Precious current
      XS1100SF Ruby gone to a better home
      KZ900B MIA stolen (ALL bike thieves MUST GET OFF THE PLANET more politically correct ???)
      • Bigfoot
        XS-XJ GURU
        • Sep 2005
        • 1422
        Thanks for the replies. The headlight increases nicely when I rev it up so maybe my problem is fixed. I will still get the multimeter out and test it tonight.
        Harry
        '79 Standard
        '82 XJ1100
        '84 FJ1100
        Acta Non Verba
          So... Electrical is all you're fessing up to at this point??
          • Bigfoot
            XS-XJ GURU
            • Sep 2005
            • 1422
            yep, just electrical..... and women. But I don't think the last one really counts. I mean does any straight guy really understand them?
            Harry
            '79 Standard
            '82 XJ1100
            '84 FJ1100
            Acta Non Verba
            • XJOK2PLAY
              • 2099
              • Skiatook, Ok.
              Hey Bigfoot...
              As Tod can most certainly verify for me...My reply is a loud "NO WAY!!!
              And I've had 28 years experience at that troubleshooting technic!
              2011 Kaw Concours 14 ABS
              • Ivan
                • Jul 2008
                • 2524
                • Hutchinson KS
                Harry,
                Go to the parts store and get an inductive ammeter. SOme DVOMs have a clip looking thing that you can use, but there are cheap ones that are just a round gauge that has a couple grooves in the back. All you do is hold it next to the wire in question and it reads out the amperage. Most of them have a x1 slot and a x10 slot.
                Here is the snap-on model.
                If you have that and a volt meter, you can do the V=IR thing and figure out how much resistance your battery has when in operation. The great bit about this information is that it is absolutely worthless, which is the best kind of info IMHO.
                Ich habe dich nicht gefragt.
