bike wont shut off
  • Filter
  • bike wont shut off
    The problem started ,batt drained ,headlight relay pullin coil energized ,pulled relay no more drein,but now ignition wont denergize dash lights stay on n such,whats up?
  • #2
    Sounds like you have some electrical issues. When you turn off the ignition, the entire bike should turn off. I would start with the fuse box, then check EVERY ground connection on the entire bike. Clean them with a wire wheel/brush, then re-attach them. Check the connectors for the ignition switch for corrosion as well. You'd be suprised how little corrosion it takes to kill a connection. HTH.
    • #3
      Corrosion will usually show as a bad or not made connection. This sounds like the key switch is not actually rotating enough or the internals are not moving to disconnect the circuit. ( I've never had one apart so not sure how they work inside).
      • #4
        wont shut off
        Ive since read more on the forum and someone had the same thing ,theirs was the key switch connector done some melting and got together ,will check that first ,thanks for the return
        • #5
          When I need to clean the electrical connectors, after disconnecting the battery, I spray them with battery terminal cleaner and let them soak of a few minutes, brush them with a small tooth brush size steel brush to remove the really stubborn crud, then flush them with electronic cleaner. they come out looking like new, and adding a little dielectric grease helps keep them that way.
          Fastmover
          lion". SHL
          78 XS1100e
