Bad vibrations
    The bead locks are 180 degree apart! they SHOULD offset each other. IF the shop put them ~120 degree off, one lock is in place of the tube air fitting.
    JAT
    • wa407mpp
      • Jul 2007
      • 717
      There are only two bead locks on the rear wheel, they balance out with the valve stem. Here's a tip, Always take a case of beer with you if you take a Conti Tour or similar tire to be mounted on your rear wheel. They won't throw wrenches at you when you come back to pick it up, and if they do,the beer will impair their aim.
      Fastmover
      lion". SHL
      78 XS1100e
      • cueball
        • Jun 2003
        • 375
        • Nth Albury NSW Australia 2640
        Tyre balance
        Throw bead locks away, block holes with bolts with silicone, fit tubeless tyres. I did this on two bikes over 4 year period. Absolutely no problems. Also get much better tyres IMHO
        • RUSH
          • Feb 2005
          • 214
          • Lake Stevens, WA
          Thanks for the help. The dealer fixed the problem but never accepted responsibility. I did get my old tire back too, it only had 2k miles on it.
          First bike was an: 1978 XS1100
          Second bike is an FJR1300.
          Now I'm restoring a '79 XS1100.
