Torque Specs for Rear Wheel Clutch Hub
  • Phoenix Rider
    • 460
    • Port Perry, Ontario, Canada
    I have replaced the 2 O-rings in my back wheel that are underneath the splined "Clutch Hub". This is the unit that has the 6 bolts attached to it. However I am unable to find out what they tighten back up to. If anyone knows the torque setting it would greatly be appreciated.
    Thanks,
    Wayne Reddin
    80 XS1100 SG "Phoenix"
    "We are the type of band that if we moved in next door to you...Your lawn would die"
    Lemmy from Motorhead
    I can't find any torque specs for the rear wheel clutch hub (cush drive). If it was me doing this, I'd use threadlock blue (if they are not self-locking nuts) and tighten them up real good using a regular legnth 3/8 drive ratchet. This way they really can't be overtightened. You can also kinda go on how much torque it took to bust 'em loose for tightening them. JMHO. HTH
