New Fuse Block
  • rpgoerlich
    • Dec 2007
    • 643
    • Katy, Tx
    New Fuse Block
    After having problems with the 80G shutting down when put in gear, I went through all the connectors. Most were really corroded. The fuseblock wasn't too bad but I elected to replace it anyway. It starts and runs alot better. Fuses are temporary until I get some more. I mounted it with longer mounting screws for the backplate mount so the wiring would come above it and through the bottom opening.
    Richard
    Very nice looking install. Did that resolve your issue of when you put it in gear?
      I suggest labelling the connections on the fuse block for future troubleshooting. Could really help several years down the line when you forget which one is which.
      • rpgoerlich
        • Dec 2007
        • 643
        • Katy, Tx
        Stalling problem resolved, Once it dried out... I suspect the corroded connectors didn't help.
        Labels will be installed once I remake them with the Kroy.
        Richard
        • GARTHXS
          • 1631
          • Seattle
          I agree
          this is what my 78 e looks like
          91 kwaka kz1000p
          Stock
          ( Insert clever quote here )
