The vacuum advance mechanism on my 78E chatters at certain rpm's. It's a very unnerving sound if you've ever heard it. I've read all the posts on this topic and have been fighting it since I got the bike two years ago. This year I installed new carb boots and cleaned & synced the carbs. Chatter is somewhat less, but still unacceptable. I've also tried new heavier vacuum hose. It is hooked up to the proper nipple. The vac diaphragm holds suction and the mechanism moves freely (ie: not sticky). There are only about 28,000 kms on the odo. The bike performs very well with the vacuum hose disconnected and plugged with a small metal screw in the end. I have a couple questions:
1) I've read that there is also a centrifugal advance that operates in addition to the vacuum advance. Does this unit function thoughout the rpm range?
2) What are the risks of running with the vacuum advance hose disconnected and plugged?
Comments?
Comments?
