Seafoam thu the boots
  • oseaghdha
    • 1075
    • N43.02.5,W88.14.2
    Has anyone tried feeding Seafoam in thru the boot vaccuum nipples?
    Thinking I have some grunge on the valve seals.
    XS1100SF
    XS1100F
  • Crazcnuk
    • 2980
    • Hinton, AB, Canada
    Putting seafoam in there wouldn't put it any different place than with the gas. It would still be in the intake system.
    The valve seals are on the other side of the head (top) under the valve springs.
    '05 ST1300
    • tinman905
      • Aug 2007
      • 946
      • Orangeville,Ontario ,Canada
      Pour it the engine and let it idle for a while but don't ride it too far or at all. That will clean up the inside of grunge.
      BDF Special
      • cowboybob998
        • Mar 2009
        • 371
        • KC MO
        I put half a can in the crankcase and half a can in the gas tank, have just been letting it warm up runing it for about 10 to 15 min. for the last few days, should i change the oil and get it out of there ?
        1979 xs1100 f
        142 main, 45 pilot, Jardeen crosover 4/2, no air box
        floats @ 25.7
        1979 xs1100 F
        1978 gl 1000 goldwing
        1981 gl 1100 goldwing
        !986 venture royale 1300
        Just an ol long haired country boy, come to town to spend some egg money
        when ya get bucked off, get back on
        • blue giant
          • Aug 2007
          • 880
          • Ontario, Canada
          Like James said, don't ride it hard or very far. When I did mine I took it for a short run up the road and back to get the engine up to temp and then did a complete oil and filter change.
          Oil was as black as your boot and it cured my clutch slip!
          Paul
          1983 XJ1100 Maxim
          1979 XS1100 Standard
          1980 XS1100 Special
          • dbeardslee
            • 4385
            • Maineville, OH
            Somebody will probably be along here before long to tell you definitely don't ride it with seafoam in the crankcase (and it's usually TC) - idle only for maybe 10-15 minutes (with a fan blowing on the engine). It really thins out the oil, and there have been reports of bearing damage as a result - same as when you get gas leaking past your fuel valves and getting into the crankcase. That being said, I did it by the label instructions and ran a couple hundred miles with no problems. But then I've always been lucky. Wouldn't do it again, though.
            On the valves, the grunge usually comes from the valve seals. If you're getting that oily looking stuff on your plugs after it's been sitting a while, might be time for some new seals. They do wear out.
            • petejw
              • 2269
              • sydney australia
              You could run it thru the nipples but you would need
              to put an aquarium valve to restrict flow otherwise it will suck to much in and a hydrolic lock will occur.
              Personally i wouldnt see the point in doing it this way,
              be better off putting more in the fuel and running it thru the carbs.
              pete
              new owner of
              08 gen2 hayabusa
              former owner
              1981 xs1100 RH (aus) (5N5)
              zrx carbs
              18mm float height
              145 main jets
              38 pilots
              • Ivan
                • Jul 2008
                • 2524
                • Hutchinson KS
                Good old Automatic Transmission Fluid works well for pulling into vacuum ports to clean the combustion chambers. Probably much cheaper than Seafoam. It also makes some great smoke signals, so expect the local tribals to come wanting some barbqued deer.
                ATF also does a fair job at cleaning sludge from the internals of engines. Usually about 1/4 ATF for about 200 miles and change the oil.
                Would you believe the stuff also works great in automatic transmissions?
                Ich habe dich nicht gefragt.
                • oseaghdha
                  • 1075
                  • N43.02.5,W88.14.2
                  Yeah Ivan,
                  I have used ATF like that in my car before. I also poured it into the bike when I first found it; cylinders, and crankcase. It has a ton of detergent in it. Makes good hand cleaner too.
                  I'm starting to get a whiff of burnt oil lately, so I am hoping it's valve seals and not rings. Was thinking if I did the thru the intakes treatment, it might clean it up some. Supposed to get the backside of the valve stem. I don't want to put that concentration in the gas tank and lay down smoke screens for 120 miles.
                  XS1100SF
                  XS1100F
                  • jeffe
                    • Oct 2004
                    • 393
                    • Westerville,Ohio
                    Same results on my 78
                    78E ... Gone but not forgotten
                    2006 Kawasaki Concours....just getting to know it
                    • Woof
                      • Jul 2010
                      • 29
                      • Plano, TX
                      Has anyone tried using RXP? http://rxp.com/
                      Works great in my cars, using a 2.5oz bottle every six months gives me noticable improved performance, mileage goes from 23 to 28mpg and best of all my vehicles always pass the yearly state emissions inspection.
                      Not sure if its available outside the North Texas area but this is some really good stuff.
                      • 81xsproject
                        • 3185
                        • Fortuna, CA
                        Snake oil, most likely.
                        '81 XS1100 SH
                        Sep. 12th 2015
                        RIP
                        • Poprock
                          • Apr 2005
                          • 594
                          • Oregon Coast
                          It depends on where you get your snakes. There's a town in Oklahoma about 50 miles west of where I used to live, that has a rattlesnake roundup every spring. Thousands of them get collected. They milk 'em for the venom, then butcher a bunch and have a rattlesnake feed. Those snakes, being hatched and living in Oklahoma all their lives, ingest oil by osmosis as they scurry along the ground. The extract is both snakey and oiley, and is the only kind of snake oil you'd want to use in something you like. So snake oil isn't bad, if you're careful of the source.
                          • Woof
                            • Jul 2010
                            • 29
                            • Plano, TX
                            Just passing along some information, I know it works and that's all that really matters.
                            • Poprock
                              • Apr 2005
                              • 594
                              • Oregon Coast
                              No offense, Woof. I use Sea Foam myself. Might be other goos stuff out there too. Haven't found it yet.
