Throttle response
  • tw1980
    • Apr 2009
    • 662
    • Bend OR
    Throttle response
    Ok I've read every thing I can find.The bike runs great idle threw red line any gear.But when I rev it up to 8500 let off shift and apply full throttle immediately it hesitates for 1 sec before it starts to rev again.If I roll the throttle back on it's fine or if I hold the throttle open and speed shift it's good as well.I watched topcatgr's youtube carb videos and he didn't seem to have this problem.Can I do something to improve this or am I expecting to much from cv carbs?
    1980 special (Phyllis)
  • petejw
    • 2269
    • sydney australia
    sounds like you could be running a bit rich
    with the mains, or maybe a blocked/dirty air filter.
    any mods done to the bike? stock air box?
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • tw1980
      • Apr 2009
      • 662
      • Bend OR
      Hey ok I know every ones pulling their bikes out of the shed and trying to go for a ride.Then we notice a problem so we post a thread.I think many of us are asking what's wrong with my bike and posting threads before we even look at all the info in the tech,maintenance and repair tips.Or try to figure out the problem our selves.It's ok to post fixes as well as problems.Now that being said someone please help me with this problem I posted.For some reason I feel like mine is more important. Just kidding the weather has been really bad here and I'm getting super grumpy. Glad some of us a getting out to ride! Terry
        Pete's questions seem logical. Do you have answers to those? It may help the gurus narrow it down for you.
        • tw1980
          • Apr 2009
          • 662
          • Bend OR
          Yes Pete has valid questions 1196 kit,dyno jet stage 3 carb kits,ported head,hot cams,pod air filters,4-1 exhaust.Good morning Pete in the land down under.Sorry your riding season is coming to an end.Gooday hope I spelled that right. Terry
            Hey Terry, Honestly, I would not know where to start from with all the mods on that machine. My only thought is that if it takes a second for it to get enough fuel to react when you hit the throttle, then it might be running a bit lean. Either that or you might have a slight vacuum leak? Just guessing to give you somthing to look into.
            • Pat Kelly
              • 3046
              • Golden Valley, AZ
              With all the mods it maybe thinks it has a turbo too and you are XSperiencing 'pseudo-turbo lag'
              Pat Kelly
              <p-lkelly@sbcglobal.net>
              1978 XS1100E (The Force)
              1980 XS1100LG (The Dark Side)
              1999 Suburban (The Ship)
              1994 Dodge Spirit (Son #1)
              1968 F100 (Valentine)
              • tw1980
                • Apr 2009
                • 662
                • Bend OR
                Turbo
                Don't I wish.Maybe next winter
                • Ivan
                  • Jul 2008
                  • 2524
                  • Hutchinson KS
                  Split second lag is because our carbs dont have an accellerator pump, so when you open the throttle quickly there is a bit off lag from the rush of air trying to draw fuel.
                  Now if its an actual bonafide full second or more, then you might look into plugs if they arent new or some other secondary ignition system problem, since that usually fails under load.
                  With all that high performance stuff, it could simply be inertia keeping the air and fuel from flowing toward the engine under such heavy accelleration. Do you leave tracers like the starship enterprize going into warp 9?
                  "What was that?"
                  "That was Spaceball 1!"
                  "Holy s@@t! They've gone plaid!"
                  Ich habe dich nicht gefragt.
                  • Pat Kelly
                    • 3046
                    • Golden Valley, AZ
                    The cams may be effecting vacuum and not allowing the slides to respond quick enough. I would thing that the dynojet kit would have addressed this but that's where I would start looking, the vac. slide springs. Dyno may have lighter springs that you could try.
                    Pat Kelly
                    • petejw
                      • 2269
                      • sydney australia
                      Hey Terry,
                      Morning to you,
                      nothing to be sorry for, might be winter coming on,
                      but we get to ride all year round :-)
                      The reason i suggested main jets, blocked air filter a way
                      of checking main jets is to hard throttle to 8-8500
                      and then back off suddenly to 6000, if the bike stumbles on decelartion the jets are usually a bit rich, if the bike increases in revs its running lean.
                      Im running dj kits in mine, the stage 3 has really large mains 138, im running dj128mains
                      with pods and and fairly open 4-1 exhaust. Even with the cam mods you have the stage 3 could b a it 2 big.
                      pete
                      new owner of
                      08 gen2 hayabusa
                      former owner
                      zrx carbs
                      18mm float height
                      145 main jets
                      38 pilots
                      • tw1980
                        • Apr 2009
                        • 662
                        • Bend OR
                        dj 140's.I think I have the mains right but it's certainly easy enough to test as you suggest Pete.I'm going to make sure that I have all carb settings 100 % right.Then I think I'm going to contact dyno tech support as Pat suggested.I think you guys are onto something.It does seem almost like the slides aren't responding quickly enough. Thanks every one Terry
                        • tw1980
                          • Apr 2009
                          • 662
                          • Bend OR
                          Well thought it might be time to update this thread.Since my last post I've been playing and tweaking.Here goes 136 mains,3rd slot from top on needle,2 1/2 turns idle mixture screws.I also trimmed slide springs to 4 3/4 in.I still have a very slight skip 6000-7000 in 1st and 2nd but when I hit 3rd it's like she has an after burner.She no longer hesitates when I shift gears.I've never felt anything like it.I should have measured my arms before I went riding tonight. I think they're longer now.I think I'm finally almost there! Thanks for all the help every one. Terry PS I should also mention I installed a set of MikesXS green coils.
                          • petejw
                            • 2269
                            • sydney australia
                            Good to hear you got it all sorted.
                            pete
                            new owner of
                            08 gen2 hayabusa
                            former owner
                            zrx carbs
                            18mm float height
                            145 main jets
                            38 pilots
