I bought some used engine parts that came from a low-mileage (~14K miles) 1981 XS1100LH Midnight Special that, other than disassembly for sale, has not been touched since it was made back in 1981.
I am attempting to repair the damage but cleaning and careful inspection have revealed an un-Godly amount of general stupidity and carelessness in evidence.
Main Oil Gallery Blocked Since 1981
The main oil gallery is partially blocked by a piece of metal protruding into the middle of it from the oil filter gallery.
The metal blocking the oil gallery is the lower threaded part of the casting for the Union Bolt (oil filter housing bolt). It was left there at the time of manufacture back in 1981 and no one has touched it since. Fortunately it didn't break off!
Lower Engine Case Damage During Assembly In 1981
A large, deeply scratched line goes all the way across all five main bearing cutouts in the lower half of the engine case. The scratch damaged all five lower main bearing shells. Main bearing cutout #4, the lower half of the thrust bearing, is shown.
Lower Main Bearing Shells Damaged
The ten common bearing shells.
The damage to the back side of all five main bearing shells caused by the large scratch across all five bearing cutouts in the lower engine case.
The shiny spots in a line between the black marks show that the damage penetrated through the entire bearing and raised the bearing surface enough to wear against the crankshaft journals.
Regards,
Scott
Regards,
Scott
