I just pulled the carb apart last night. The seats for the needles on two of the carbs came out when I was using my impact driver. Are they just set in there? Presssed in? I'm concerned and have not found a good detail source to use as a guide. First time I had to go this far due to corrosion. I'm still having alot of fun though.
Gene
Gene
. The main jet screws into the bottom end of that nozzle to hold it in place and position that jet. I would spray the tar out of everything in there with PB blaster and let it soak for a while before you try to pull anything.
