Seat attachment bolt assy
  • Seat attachment bolt assy
    Anybody out there have one of these bolt assemblys used to attach the seat to the frame on a 81 Special?
    THX, Duane
    I don't have one but I just saw a new one on ebay
    1980 special (Phyllis)
    1196 10.5 to 1 kit,megacycle cams,shaved head,dynojet carb kit,ported intake and exhaust,mac 4 into 1 exhaust,drilled rotors,ss brake lines,pods,mikes xs green coils,iridium plugs,led lights,throttle lock,progressive shocks,oil cooler,ajustable cam gears,HD valve springs,Vmax tensioner mod
      Originally posted by TooLax View Post
      Anybody out there have one of these bolt assemblys used to attach the seat to the frame on a 81 Special? THX, Duane
      Hi Duane,
      luckily when I bought a proper seat to replace the KQHB uglything it had them on it. But what a less than optimum system it is.
      You could use the search function to look for a recent string about replacing that device with a quick release latch from a bicycle.
        Duane - I've got a couple of the slotted mounts with their spacers, but I don't have the bolts. You could probably use appropriate sized carriage bolts. The mounts came off a standard seat, but according to the fiche they're the same on a special. Yamaha part # 2H7-24738-00-00.
          Originally posted by fredintoon View Post
          Hi Duane,
          Here is the quick release link.
          http://www.xs11.com/forum/showthread.php?t=12180
          1980 XS 1100SG
          Dyna 3 Ohm Hi Output Coils
          Pod Filters
          DynoJet Kit
          T.C.'s Fuse Block
          V-Max Auto CCT
            Depending on what you are missing, you can improvise form the hardware store. One of my bolts broke off and I just used a dremel to cut the welds off the bolt, popped it out, got a replacement and JB Welded it into place. The welds just keep it form turning. Might be tough to find that long nut though.
              Hi Duane.
              I was hoping John told you about that since I forgot to tell you. Honestly forgot all about it until this post. Let me get in touch with Russ. With all those parts bikes Bob Jones had, I'm sure we can get you set back up if you want it back the way it was.
              If I remember right, it's just that barrel nut, washer and lock washer that's missing isn't it?
                Well... someone told him anyway...
                Honestly, the quick release is a great alternative... John and I have both been thinking about going to this set up... we just haven't... yet...
                81 SH Something Special
                79 SF MEAUQABEAUXS
                81SH Nor'eas tah (Old Red)
                80 LG Black Magic
                78 E Standard Practice
                James 3:17
                “Alis Volat Propriis”
                Yamaha XS 1100 Classic
                For those on FB
                  I, too, really want to do the quick release seat mod. Gotta finish the MS project first though.
                  '81 XS1100 SH
                  Sep. 12th 2015
                  RIP
                    With the way that plate attached to the seat is on the 81, it seems like you could install the hook part that attaches to the XJ seat, then the quick releases mount to the frame. Any reason you couldn't use this system? (Though I haven't really taken a look as to how the recepticle that recieves the hook is mounted to the frame.)
                    Last I saw.. it was still politically correct to refer to a married couple as Mr. AND Mrs. John Wilmot for eg. So... John told him, but apparently it was MRS. John that told him!
                      I did the same thing, only with a Bridgeport, a 3/8 solid carbide endmill, and a TiG. Might have been overkill.
                      Ich habe dich nicht gefragt.
