Yukonman was up to Revelstoke this past weekend so we could replace the cam chain on his '78 E. With somthing in excess of 134,000 kms (83,750 miles) on the clock, it had got to the stage that the slack adjuster could no longer keep the chain tight. In fact, with the cover removed, you could feel slack in the chain where it runs across the guide (part number 7 here) between the cams. With the new and old chains placed side-by-side, and carefully aligned at one end, here is how much stretch there was:
Once the new chain was installed and the slack adjuster 'adjusted', the effect was immediate - there was no slack across the guide.
And, just in case anybody was wondering, if the rear nut from the #3 camshaft cap on the exhaust cam happens to slip out of your fingers and it falls down inside the crankcase along the chain damper assembly,
you will probably find it by removing the exhaust system and the oilpan and reaching up and in with your right hand from the left side of the bike, on the forward side of the opening just to the left of the centreline of the motor. DAHIKIJD
