They should be fine, but a bit pricey for me, so I used the Plasti-dip spray repair method.
Another Carb Issue??
If you could spin the diaphram are you saying it spun on the slide assembly? or spun in the carb? There is supposed to be a tab on the outer diameter that will match a space in the carb body top.
When dipping carbs, as others have stated before, watch you dont get your butterfly seals in it, they are hard to replace if they can be had and will cause vacuum leaks if the cleaner gets them.
Yeah, sounds like they are lean to me, stumble until warmed up, and then WOT stumble, running out of fuel.Life is what happens while your planning everything else!
78 XS750Comment
Diaphram
I meant that it spins on the slide assembly. I have already replaced the shaft seals or are you talking about the little brass half moons that are riveted to the butterfly?If you could spin the diaphram are you saying it spun on the slide assembly? or spun in the carb? There is supposed to be a tab on the outer diameter that will match a space in the carb body top.
The shaft seals I bought from MikesXS.78 XS1100E Standard
Coca Cola Red
Hooker Headers
1979 XS1100 Special
1980 XS Standard
2006 Roadstar Warrior
http://i408.photobucket.com/albums/p...um/warrior.jpgComment
ok...mine do not move on the slide I know.
I meant the shaft seals on the butterflys, or whatever the real carb gurus talk about when they tell folks to not dip the butterflys
I never took mine down that far.
Did you make sure both sets have the same jetting?
78 XS750Comment
I have not measured them so I don't know IF they are 34mm, but they are labelled for the BS34 carbs, which are the later model carbs, the 80-81 series. They are larger, wider than the earlier model carbs, and will NOT work with the 78-79 year carbs.
I've checked the Yamaha microfiche, and the part #s for the early 650 carbs...77 as well as the 79 are different than the ones for the 79XS11.
But I don't have a 650 bike/carb to truly verify this for the OTHER slide that is listed for the BS38 carbs.
I know folks have stated that all of our carbs were BS34's, just different series, but the slides ARE different sizes between the early and later ones, and the slides that Mikes and PNM offer are only for the later model carbs!
T.C.T. C. Gresham
Diaphrams / Slides
Ok.. That's not what I was hoping for!! So is there anybody that sells the diaphram/ slide assembly?I have not measured them so I don't know IF they are 34mm, but they are labelled for the BS34 carbs, which are the later model carbs, the 80-81 series. They are larger, wider than the earlier model carbs, and will NOT work with the 78-79 year carbs.
T.C.78 XS1100E Standard
Coca Cola Red
Hooker Headers
1979 XS1100 Special
1980 XS Standard
Yes, regrettably BIKEBANDIT, are you ready??
Might be better off finding a used bank, or getting a bank of later model XS11 carbs, not as fine tunable, but parts are more available?7: DIAPHRAGM ASY
21390-001 Enter 0-99 $231.71
T.C.T. C. Gresham
Yikes!
Again.. Not quite what I was hoping for. I have some spares but like me, they are old. Reckon I am going to be bidding on ebay soon.
If I were to spend that kind of money, I might as well just replace with an after market set of carbs but I want to stay original.78 XS1100E Standard
Coca Cola Red
Hooker Headers
1979 XS1100 Special
1980 XS Standard
The diaphragms come up as a set of for on EBay all the time. The used to sell for around $100/set, but with $34 shipping!
The ones on there now are $156/set, but I didn't check the shipping.Nice day, if it doesn't rain...
'05 ST1300
'83 502/502 Monte Carlo for sale/tradeComment
Diaphrams
I've seen these but I do not think they are for 78-79? Don't know how the diaphrams come off or how to change just the rubber? Anybody done this before??78 XS1100E Standard
Coca Cola Red
Hooker Headers
1979 XS1100 Special
1980 XS Standard
Yeah it's not that hard but you have to be careful.The set I got off ebay had instructions.Get a small bottle of zippo lighter fluid to use for lubricant.Then I used a small screw driver to push the diaphragm into the slide.I marked where the notch was with a sharpie.Also it's a good idea to remove any burs from to screwdriver before you start. Terry1980 special (Phyllis)
1196 10.5 to 1 kit,megacycle cams,shaved head,dynojet carb kit,ported intake and exhaust,mac 4 into 1 exhaust,drilled rotors,ss brake lines,pods,mikes xs green coils,iridium plugs,led lights,throttle lock,progressive shocks,oil cooler,ajustable cam gears,HD valve springs,Vmax tensioner modComment
Old Rubber
How did you get the old diaphrams off of the slide?My 78-79 slides look to be glued.Yeah it's not that hard but you have to be careful.The set I got off ebay had instructions.Get a small bottle of zippo lighter fluid to use for lubricant.Then I used a small screw driver to push the diaphragm into the slide.I marked where the notch was with a sharpie.Also it's a good idea to remove any burs from to screwdriver before you start. Terry78 XS1100E Standard
Coca Cola Red
Hooker Headers
1979 XS1100 Special
1980 XS Standard
Well, the pros have a special press to pull the top plastic ring off.
Somewhere on this site is a description where he cut that top ring to get it off, but has no problems with it falling off after.Nice day, if it doesn't rain...
'05 ST1300
diaphram replacement
Heres a link to the carb diaghram replacement i did not to long ago.
this was for later model carbs, not sure if its the same for the early models.
hope this helps you out a bit.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url]Comment
Late models
The diaphrams/slides in your thread are obviously for >80 models. These look completely different from mine. Also, all of the diaphrams I see for sale on ebay and other sites are for 1980 models and up. Thanks for the information, I am going to cut an old one I have apart to see how it is put together.Heres a link to the carb diaghram replacement i did not to long ago.
hope this helps you out a bit.78 XS1100E Standard
Coca Cola Red
Hooker Headers
1979 XS1100 Special
1980 XS Standard
