Tribute to my Dad bike
  • Crazcnuk
    replied
    I want max power and 45+mpg!
    I have 4:2 turnouts and K&N element with 115's and 45 pilots. Runs very strong, but have not ran enough gas through it to check mileage.
    For some reason, our Canadian models appear to come standard with 45 pilots and 110 mains, and wierd needles and needle valves.
    Leave a comment:
  • XSPastor
    replied
    No toes stepped on here! Just reporting what works for me. I'd rather error on the side of rich as long as the plug color is good and it runs well.
    Leave a comment:
  • 81xsproject
    replied
    I don't want to step on toes, but testing with my O2 sensor showed 120's to be quite a bit too big especially with 45 pilots. Even with my pods and a large 4-1, 117.5 with 45 pilots is as rich as is desirable for max power. I also live at sea level.
    Leave a comment:
  • XSPastor
    replied
    YMMV but here's my setup...
    I've got an 81 special and, as you can see from my signature, I'm running 120 mains (rounded up on TC's advice) and stock pilot jets with a 4 to 1 and a drilled air box with a K&N. It runs well for me. Nice plug color, plenty of power.
    Leave a comment:
  • gene
    replied
    Makes sense now. Thanks for connecting the dots. Looks like 117.5 main and 45 pilot. Might have to round up to 120 on the main.
    Gene Jr
    Leave a comment:
    replied
    Congrats and good luck
    Hey Gene, awsome you are oding this XS11 tribute to your dad! Yes, the stock jets in the 81 carbs are 42.5 pilots and 110 mains. The mains are smaller due to the unshielding of the pilot jets form the earlier carbs. So the main no longer needs to be lartge enough for both fuel sources.
    There is a tech tip on jetting sizes. You may have found it, the size changes it recommends should be from the 110 and 42.5 sizes. You may also want to note they chnaged the float setting down to 23 +/- 0.5 mm. Lots of folks here run the "pod" filters you mentioned.
    Leave a comment:
  • gene
    started a topic Tribute to my Dad bike
    Hey Guys, I bought an 1981 XS1100 Special. Got it cheap, but wow this is going to test how much my dad taught me. I pulled out the air box and carb this morning. The jets I have are 110 main and 42.5 pilot jet. If I use the standard scheme, I will only end up with a 117.5 main. Did they tone these down that much in 81'?
    With a 4 into 1 exhaust and drilled air box with K & N the rest are using 145 main and 45 pilot.
    I just bought the intake boots on line, but I'm waiting to order the jets.
    Also, my dad ran velocity stacks and removed the air box. Anything wrong with that? This bike is going to be tough to keep stock.
    Tank has 3 dents who would you guy's recommend I send this thing to?
    Thanks for your help in advance.
    Gene Jr
