My first gear was starting to go out again, so it was time to rip apart the motor again. I don't know if any of you remember, but with my last motor tear down, I tried to do a washer swap on 1st gear like you do on 2nd gear. What I did, was find a washer that was exactly HALF the thickness of the stock washer. I left one of these washers where the original was, then moved the other one to the back side of first. This moved 1st gear towards 4th half the distance than if I'd done the stock washer swap.
Let's just say that the results weren't quite as hoped. I could hear the gears hitting a bit when the bike was in 4th gear. Another REALLY fun side effect.. if the bike was in neutral with the clutch out, and you revved it pretty good.. the transmission would jump into first!! lol. So.. a washer swap on first gear moves the gears too close together.
I tried this washer swap since 1st gear seems to be the one that craps out on the XJ versus the XS 2nd gear. Same motor, same trans... no idea why it's like that. I've had some great help from Jeremy (Montreux_Blue) down here at John and Kat's house, and John has chipped in when he could.. but is still a bit hampered by his recent back surgery. He is getting around better than I expected though. We got the motor pulled and cases split last night (Friday night). When I got into the motor, I saw that 2nd/5th weren't much better. Luckily I had left some gears down here from the last Meeting of the Minds, and I had a set to grind on. I had previously done 1st/4th gears before I got here. Here's how the motor looked this afternoon...
And we finally got the motor somewhat together and stabbed back in the frame tonight.
Hopefully I'll have it finished up in the morning. Today, I also rebuilt the starter clutch, cleaned the carbs, and got the valves all shimmed back up. Next weekend.. I get to do it all again with another member's XS! lol.
