Hi,
Having some clutch slips on my 1980 special, particularly in 3rd, 4th, 5th gears when I roll on it... somewhere around 4k-6k rpm, usually around 6krpm though. Thinking about redoing the clutch this summer sometime, and my question is...
will this problem be solved by replacing the friction plates, clutch plates, compression spring, and pressure plate #2 ?
do I need to go further than this?
do less than this?
I'm not afraid of tearing into things, and can follow manuals quite nicely... but I lack the experience that some of you folks have, so I definitely appeciate the help.... past, present, and... of course... future.
Thanks,
Sam Whitcomb
do less than this?
Thanks,
Sam Whitcomb
- then new plates are the answer usually and should solve your problem. I'd advise on standard clutch springs if you are going to change them too as the high performance ones make the operation a little stiffer - which is a trade off if you drag race or something, but not really needed for the road.
