Where do all these hoses go?
  • Giggity
    • Mar 2009
    • 113
    • Longmont, CO
    So I've got the carbs and fuel tank on but cannot figure out where all the hoses and tubes go. Clymer b&w pics don't help much. I will be using pod filters.
    Does anyone have a detailed diagram or photos so I can get everything back together and try to start her this weekend?
    Thanks.
    1979 XS1100 Standard
    Putting it together........
    No diagram, but maybe I can help.
    1. Lower T's between the carbs are your fuel lines. Attach to petcocks, larger nipple.
    2. Upper T's are vents, leave them open, do not plug.
    3. Small petcock nipples go to carb boot vacuum on 2+3
    4. Vac advance hose goes to the nipple on carb body #2
    5. Large crankcase breather hose to remain vented, maybe put a breather like this on it.
    HTH.
      How far apart do you have the hoses? Did you leave them connected to the carbs? If so, the memory in the hoses should give you some idea of where they should plug back in. The diagrams in the manual are all I ever referred to to get it all back together.
      • Giggity
        • Mar 2009
        • 113
        • Longmont, CO
        Phil,
        Thanks for that. So it's o.k. to have unfiltered air going into the carbs per step 2?
        Boot nipples on 1 and 4 should be plugged?
        CB,
        The carbs were off the bike when I bought it so I have no reference.
        I could kind of tell by the memory of the hoses but my big ham hands also have a hard time getting around in there.
        • kirmit77
          • Mar 2009
          • 464
          • Kingwood, TX
          Hope this might help, IDK if this is from the clymer but this helped me. Also if you need it i have it off the bike if you would like a pic of that too!
          [IMG][/IMG]
          Austin Ingalls
          MIDNIGHT FURY
          1979 XS1100 Special [Full Restore Project]
          XJ maxim rear air shocks
          KERKER 4-into-1 exhaust
          Pod Filters
          Money pit.......
          BLACKED OUT
            Originally posted by Giggity
            Phil,
            It's ok to leave them open, but some prefer to run them both to a T fitting and then add on an inline fuel filter so no bugs, dirt, etc. enter. Boot nipples on 1 + 4, plugged. That above diagram is for the Special only.
            • Giggity
              • Mar 2009
              • 113
              • Longmont, CO
              Thanks for that. I do not recall seeing it in the Clymer.
              Does that diagram show the "octopus" I've read about?
              My bike doesn't have one.
                Yes, that is the octopus.
                • kirmit77
                  • Mar 2009
                  • 464
                  • Kingwood, TX
                  I have the manual and a different wiring diagram for the bike if you want it. If so just PM me so I can get your email.
                  Austin Ingalls
                  MIDNIGHT FURY
                  Pod Filters
                  Money pit.......
                  BLACKED OUT
                  • Giggity
                    • Mar 2009
                    • 113
                    • Longmont, CO
                    Kirmit - PM sent
                    Where does this tube go, where does the bracket attach?
                    [IMG][/IMG]
                    Thanks
                      That bracket is attached to the bolt that holds the air box in place under the seat. On mine the bolt goes through that bracket, then through the air box bracket, then into the frame. The tube is the middle drive vent I believe, and now I am wondering where mine is because it ain't on that bracket.
                      • Giggity
                        • Mar 2009
                        • 113
                        • Longmont, CO
                        I hope you find it.
                        So the open end doesn't connect to anything?
                        • randy
                          • Dec 2003
                          • 4521
                          It's a VENT
                          It VENTS to the atmosphere.
                          • Giggity
                            • Mar 2009
                            • 113
                            • Longmont, CO
                            CC breather hose is a vent that plugs into the airbox. I was just checking.
                            Thanks again for the manual.
                              The CC breather plugs into the air box only because it is venting ..well..the crank case and therefore might have some exhaust gases with unburned fuel vapors so they can get recycled back to the engine. Of course, the middle drive will not have any such stuff in it, or at least it better not.
