carb cleaning
  • cowboybob998
    • Mar 2009
    • 371
    • KC MO
    carb cleaning
    hey yall, i am new here, been reading all i can on carb cleaning, gona throw this out there and see what yall think.
    Read on another web site "poor mans carb cleaner" take distiled water and boil the carbs, what yall think ?
    1979 xs1100 f
    142 main, 45 pilot, Jardeen crosover 4/2, no air box
    floats @ 25.7
    1979 xs1100 F
    1978 gl 1000 goldwing
    1981 gl 1100 goldwing
    !986 venture royale 1300
    Just an ol long haired country boy, come to town to spend some egg money
    when ya get bucked off, get back on
  • dbeardslee
    • 4385
    • Maineville, OH
    Cowboy - Welcome. I've heard of people boiling carbs, but haven't indulged in the practice myself. A couple cans of carb cleaner, and a can of brake parts cleaner does it for me. It's not as cheap as water, but I save a fortune not having to heat it up .
      Some of the people here HAVE tried the boiling method with good results. It's not JUST distilled water, you need a little acid in it as well! If you add a little distilled vinegar to the water, you have the acid you need!
      IF you go for plain carb cleaner, use the spray type. DO NOT SOAK THE CARB BODIES!! There are rubber seals in the butterfly shafts, and they WILL cause you endless problems if you soak the carbs!
      Do a search on carb cleaning or triple clean, and you should find LOTS of threads!
      Welcome to the site!
        Sounds like a neat idea, but I don't have a cooking pot big enough to fit my carb rack into... If I did, I don't think I'd want to ruin it by cooking carbs in it.
        • lakecountrydave
          • Aug 2007
          • 384
          • Phoenix, AZ
          DiverRay - Are you saying that if I boil the carbs I don't have to completely disassemble them? Will the rubber melt or distort? That sounds a lot easier.
          Dave
          1979 XS1100SF Special
            Hi 'Bug,
            go buy a single use aluminum turkey roaster to boil your carbs in. Perhaps get two and put one inside the other, that foil is kinda frail.
            If you share your life with a significant other wait until she's gone shopping before you pop the roasterful of carbs on the kitchen stove.
            There's things that some women just do not understand.
            • dbeardslee
              • 4385
              • Maineville, OH
              Never having done it, let me ask this question. Will boiling the carbs really get the small orifices and passageways clean inside the carbs? Seems to me like you may still need a can of carb cleaner to complete the job, but who knows?
              • latexeses
                • Jun 2008
                • 1491
                • California
                I was lucky enough to have a sonic cleaner at my disposal.
                Took the carbs totaly apart. I left the butterflies alone.. I didn't mess with the return springs either. I sprayed carb cleaner through every hole in the carb body to clean up the major junk. I thought they were pretty clean too.
                Dropped the individual carb bodies in the sonic cleaner with enough water to cover the carb body, a good squirt of Dawn dishwashing soap and a couple of "glugs" of Simple Green.
                Turned that sucker on and in three minutes you could barely see the bottom of the tank for all of the crud that ran out.
                If you can lay hands on one I highly recommend it for the carbs.
                The solution won't hurt the seals on the butterfly shafts either.
                Everything on hold...
                • kirmit77
                  • Mar 2009
                  • 464
                  • Kingwood, TX
                  sonic cleaner
                  Where would you find one of those sonic cleaners?????
                  Austin Ingalls
                  MIDNIGHT FURY
                  1979 XS1100 Special [Full Restore Project]
                  XJ maxim rear air shocks
                  KERKER 4-into-1 exhaust
                  Pod Filters
                  Money pit.......
                  BLACKED OUT
                  • robert_hollis
                    • Dec 2008
                    • 17
                    • Houston, TX
                    Harbor Freight carriers a couple of different small ones for cheap.
                    • cowboybob998
                      • Mar 2009
                      • 371
                      • KC MO
                      I think I am off to harbor fraight, forget the boil out, thanks yall
                      1979 xs1100 f
                      floats @ 25.7
                      1979 xs1100 F
                      • kirmit77
                        • Mar 2009
                        • 464
                        • Kingwood, TX
                        I need one so I can put all of my carbs in it without taking them apart. The one they have that might fit is like $170! YIKES might as well just soak them in carb cleaner.......
                        Austin Ingalls
                        MIDNIGHT FURY
                        Pod Filters
                        Money pit.......
                        BLACKED OUT
                        • randy
                          • Dec 2003
                          • 4521
                          How do you expect to get them clean without taking them apart? And, DON'T soak them in carb cleaner without taking all the rubber bits out.
                          • kirmit77
                            • Mar 2009
                            • 464
                            • Kingwood, TX
                            let me rephrase
                            I do not want to have to take the bodies apart form eachother. I have them completely disassembled. Also dont want to have to take off the choke assembly and the butterflys. You can go look at my thread to see the pics of my carbs already apart.
                            What should I do?
                            Austin Ingalls
                            MIDNIGHT FURY
                            Pod Filters
                            Money pit.......
                            BLACKED OUT
                            • DenyP
                              • 599
                              • Staples, Minnesota 56479
                              This is an interesting thread and I have a question or two. I am doing a set of carbs one of which is dirtier then anything I have ever seen - just loaded with varnish. Why just one of them is behond me. My last set was the carbs off the Timemachine. The carb spray and elbow grease with a brush and carb kits did the trick. Obviously I can not get the brush into the passages on this set. I am not resistant to buying toys (tools) to do the best job I can, but I joined the ranks of the unemployed this month so I must delay buying a sonic cleaning unit. If any of you have done the boiling thing I would like to hear your remarks as to how satisfied you were with the end result.
                              Thanx
                              Deny
