Electrical Question
  • Lord Grizzlon
    • Mar 2003
    • 101
    • Bklyn, NY
    Electrical Question
    AFTER WORKIN ON THE BIKE FOR A FEW WEEKS, FINALLY TOOK HER FOR A RIDE. STILL HAVE WORK TO DO. BUT, AT 1 POINT I PUT HER IN NEUTRAL AND REVED THE ENGINE A FEW TIMES TO ABOUT REDLINE, ( ONLY WAY TO KEEP GAS IN HER...LONG STORY) BUT THIS ACTION BLEW ALL THE FUSES.
    THOUGHTS, COMMENTS, CRITICISMS?
    L. G.
    1979 XS1100SF
    Exodia, "The Forbidden One"
    1988 CBR600F Hurricane
    Tempest- died Aug. 10, 2005
    198x XS850
    -no name yet-
    • 5061
    It blew ALL of the fuses? That is strange because the 30-amp main fuse should protect all of the others. I would suspect that the volt relay is malfunctioning and allowing more than 14.5 volts max.
    • Lord Grizzlon
      • Mar 2003
      • 101
      • Bklyn, NY
      THE MAIN IS THE ONLY 1 THAT DIDNT BLOW.
      L. G.
      1979 XS1100SF
      198x XS850
      -no name yet-
      • sixtysix
        No XS but XSive as can be!
        • 1958
        • Central New York State
        This is really all i can think of too. A high voltage spike took them out. Replace fuses, check voltage output acoording to book. Voltage shoul be 13ish at idle and go up to 14.3-14.5 at 4000rpm, it should not go up after that, if it does, replace the voltage regulator.
        Gary Granger
