2 issues:
1. I drained the oil yesterday and found a fair amount of metal shavings. Should I flush the crank case to make sure all are removed? What would I use?
2. I managed to strip the hex head on the final drive filler cap.
That sucker is stuck. What should I do now?
Thanks
Thanks
, and thread the hole for a short metric Allen bolt that takes the same size wrench as before and the put a nyclad nut on the back side to keep it tight.
