On my 78 XS1100E..... the PO has removed the entire baffle from both mufflers leaving them pretty much straight pipe.
Is there an inexpensive replacement muffler that will work ok with the stock headers? Or..... is there anyone who sells a replacement baffle assembly that can be fit into the stock mufflers?
Currently... the bike is XSesively loud and runs poorly at low rpm. I assume that with the reduction in back pressure at low rpms... it is causing the mixture to be too lean.
