XS1100 Stator/Alternator Cover
  • teedubb23
    • Mar 2009
    • 1
    well i have an xs1100 that leaks oil from the stator/alternator cover.. There looks like there is a rivit or factory cut in the bottom of the cover where an oil plug sits. It leaks oil from there and not quite sure if that is normal or supposed to be there. What should i do?
  • 79XS11F
    • 3563
    • Ottawa, Ont. Canada
    You likely have oil getting past the gallery plug that sits in a hole (oil gallery) behind that cover. The inside of the cover is a dry area. If it's not the gallery plug then it's likely the crank end seal.
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
