Gas Mileage
  • dbeardslee
    • Nov 2007
    • 4385
    • Maineville, OH
    Ivan - I've heard other members with the mod say it had a dramatic affect on mpgs and others that say it didn't change at all - that's why I've got my fingers crossed . I will say this, however. I gassed up and went for a 20 mile spin last night. I watch my fuel gauge like a hawk, and it is definitely decending more slowly. I'm thinkin' the key to improved fuel mileage is to take advantage of the taller gearing, as in run it at lower rpms across all the gears. Anyway, that's my theory - we'll see how well it works in practice .
    • Crazcnuk
      • Aug 2006
      • 2980
      • Hinton, AB, Canada
      Again it comes down to riding style. Just doing a mod or two is not going to change much, if you don't change riding style.
      Mpg is as much a lifestyle as it is mechanics.
      And again, there has been some evidence that riding at too low an rpm can hurt mileage.
      '05 ST1300
      • Ivan
        • Jul 2008
        • 2524
        • Hutchinson KS
        Well, I think the true purpose of the 750FD is to get closer to the 160 mph mark.
        Actually, if you were to drop the floats a few mm and drop the needle, you could lean the mid range cruise where the taller gears like to ride at 60 mph, and go a bit bigger on the main jet to keep WOT at a nice 8:1 for power when you need it. Might help. not sure, JAT
        Ich habe dich nicht gefragt.
        • dbeardslee
          • Nov 2007
          • 4385
          • Maineville, OH
          Don't want to hijack, but...
          Definitely helps there! It's a whole new experience on the four-lane . I just went up on the jets to accomodate the pods, and I'm really likin' the way it's running. I think I'll experiment running in different rpm ranges for a while - run a tank trying to keep them around 2k, another tank shooting for 3k, etc., just to see what happens. Also want to try an all-highway ride with a constant speed of 70mph - it's only turning over 4k there. We'll see.
          • XJOK2PLAY
            • 2099
            • Skiatook, Ok.
            Dbeardslee, am I understanding correctly that you have swapped out to a 750 FD? Do you remember what your rpm's were before the swap @ 70mph? I know for a fact that my '82 XJ1100 Maxim has not had the swap done, yet seems to be very tall in the gearing, runs exactly @ 4000 rpm @ 70mph, and gets a consistant 30mpg... just went through everything, including carbs and timing and tuning. I had heard that the average rpm for stock @70mph would be around 5000rpm, and after the swap would drop to 4000rpm. Sound right?
            2011 Kaw Concours 14 ABS
            • dbeardslee
              • Nov 2007
              • 4385
              • Maineville, OH
              XJOK - That sounds pretty close - I think I was running close to 5k at 80, now it's around 4.5k at that speed. I mentioned the 4k at 70 'cause it's a more-or-less legal speed in most states, and the motor seems to like running there. The 1100 rear end is geared 3.3/1 while the 750's is 2.9/1. With a 12% taller gear, one would expect the rpms to be about 12% lower. Of course math was never my best thing . It feels like a lot more than that though - very smooth.
              • XJOK2PLAY
                • 2099
                • Skiatook, Ok.
                Since my previous post I found your thread detailing your FD swap.
                I've heard several of the ones who've made the swap make those claims, and 4000 down from 5000 rpm @ 70mph seemed to be the general concensus. Maximan's a close friend, and he and xschop, as you know, kinda created the concept.
                I just can't get over how tall geared my XJ already is. 4000 @ 70mph. If I made the swap, I can't imagine being able to take off from a stop!
                I've also been told that by using the 850 FD instead of the 750, it makes life a lot simpler (and more dependable) concerning the spacer. Maximan lost his first FD swap attempt after a few thousand miles due to failure, relating to the spacer. Said it locked up at speed!
                • dbeardslee
                  • Nov 2007
                  • 4385
                  • Maineville, OH
                  I think as long as you stay with a '79 or later FD it won't make much difference in whether it came from a 750 or 850. Mine came off a '79 750 and it was a breeze as far as the FD was concerned.
                  • Crazcnuk
                    • Aug 2006
                    • 2980
                    I think the consensus was that it drops about 700rpm in high gear.
                    '05 ST1300
                      DBeardslee has a std and therefore a 17" rear tire so his RPM at speed will vary from those of a special or a XJ which I think also has a 16" rear wheel. Obviously the smaller wheel gives lower speed for the same RPM. MY special is definitely about 5K at 70 MPH.
                      Do the XJs have a different gearing than the XS? I thought they were the same in drivetrain.
                      • garyramir
                        • Oct 2024
                        • 3
                        • fort worth texas
                        i have an issue on my 1979 xs1100 special. im getting 31 miles to a full tank of gas. there has to be a better way and something im not doing. the list is long on the things ive done to it to get it running after i purchased it about year ago. any suggestions?
                          • 1855
                          List everything you have and have done. What kind carbs, exhaust, air filter and what all have you done concerning tuning. You will get far better answers if we know more.
                            • 8733
                            Is this a typo and you really mean 31mpg?
                            • gtem
                              • May 2023
                              • 222
                              • Indianapolis
                              My '79F running a plexistar and loaded with some soft saddle bags ran around 36mpg riding out to Ohio and back on state highways (60-65mph) this summer. Which is about the same as what the previous '78E (running '80 carbs) got. My big bore GS Suzukis all did noticeably better, especially my GS1100E.
                              '79 XS1100F
                              others: '98 GSF1200S
                              Past Yamahas: '78 XS1100E, '76 XS500C
                                • 3231
                                80SG with Plexifaiing and 750 / 850 final drive mod, 39 to 41 MPG pretty much any speed I ran it. Running back roads or Interstate from 50 to 75 miles an hour didn't make much difference.
                                ZRX1200
