TooLax
  • TooLax
    • Mar 2009
    • 12
    TooLax
    Hello,
    Can anyone tell me if Bob Jones motorcycle shop is still open in Shawnee KS. Yes I am aware he has passed away. But am looking for help woth my 1981 Special and he used to do all my work. I have a nearly mint bike that has starter gear troubles and the repair is beyond my abilities. Also the parts are impossible to find.
    Appreciate any information and advic,
    Thanks, Duane in New Orleans
  • Crazcnuk
    • 2980
    • Hinton, AB, Canada
    Most parts aren't too difficult to find. Here, mostly.
    Depends on just what you need.
    I believe his shop was Merriam Cycle?
    Merriam Cycle
    5911 Merriam Dr.
    Shawnee, KS 66203
    913-677-4665
    '05 ST1300
    • Bigfoot
      XS-XJ GURU
      • Sep 2005
      • 1422
      • Kansas City, Missouri
      No, unfortunately Merriam Cycles is no longer open for business.
      Harry
      '79 Standard
      '82 XJ1100
      '84 FJ1100
      Acta Non Verba
      • xs11lover
        • 1433
        • Montoursville Pa
        I know a guy that can help but he is in Mn. PM me and i'll help you get in touch with him if you want.
        79 XS11 Special (Lazarus)
        79 DT 100
          You can still get replacement parts for the starter gear, BUT.. you will have to pull the engine and split the cases to get to it. I'm sending you a PM.
          • TooLax
            • Mar 2009
            • 12
            Thanks for the info!
            • TooLax
              • Mar 2009
              • 12
              Thanks, do you know if they sold all his bikes and inventory?
              Duane
              • TooLax
                • Mar 2009
                • 12
                Sorry but i do not know what you mean by sending a PM.
                I do appreciate the information. you said I can still get the starter gear replacement parts...do you know of a source?
                Thanks Again, Duane
                  PM = Private Message
                  There's several ways to get to the PMs, but at the very top of the screen where it says "Forums", hold your pointer over that, and a drop down list will drop down. Click on "User CP" and it will take you to your Private Message screen where I left you one.
                  You can get the starter clutch kit at Partsnmore.com, but there's a minimum order of $35.
                  • redbone
                    • Oct 2007
                    • 244
                    • Waynesboro pa
                    there's one on ebay
                    toolax,
                    there is one on ebay [starter] for a 1980 special now. see number
                    250388113028. hope this helps.
                    testing 1-2-3
                    1980 1100 mns
                      I can't see the Ebay listing here at work, but if it's a STARTER, he needs a starter CLUTCH which is inside the motor on a shaft the primary chain is around.
                      Just for your info, the engine from the piston rods down, the cases, and the drives out to the final drive are all the same for all the XS and XJ in 1100cc. The electronics such as the alternator/stator and the pickup coils differ, but the actual engines, gears, and starters all interchange.
                      • TooLax
                        • Mar 2009
                        • 12
                        Originally posted by redbone
                        toolax,
                        Thank You Sir !
                        DY
