"Whining" when moving?
  • Wolfpaws
    • Mar 2009
    • 39
    • St Louis, MO
    Bike's running and seems to operate fine other than the fuse issues which will be replaced soon, but one thing I do notice is when I'm in gear and moving the bike will "whine" at a steady pitch, but as soon as I slow down to pretty much not-moving, the noise stops. I can be in gear and stopped and it won't whine, but once I start accelerating, it'll pick up. It doesn't whine in Neutral - but then again, you don't accelerate in neutral.
    One other thing I notice is if I leave the bike for more than 15-30 minutes, I need to close the fuel petcocks or otherwise I leak fuel - yet the petcocks themselves do not seem to be leaking and are bone dry on the outside (most of the leaked fuel is coming out lower down the line).
    Any idea what could cause the whine?
    1979 XS1100 Special
    Have you checked your middle drive and final drive oils? There is a fill on the middle drive just below the air box area on the left side of the bike, open it and check the fluid level. Also on the final drive, check fluid level.
    Other idea is to pull the final drive and check for grease where the drive shaft inserts into the final drive.
    • Wolfpaws
      • Mar 2009
      • 39
      • St Louis, MO
      Looks like it might be the speedo - either the unit or the part that attaches to the front wheel. It's actually whining inside the speedo can if that's the case - we've figured out it has nothing to do with the engine revs, but with the actual speed - once you get over about 5mph, it kicks in.
      I'll just have to deal with it until I can find a round speedo that pops up on eBay or something - they're pretty hard to come by. I have a replacement cable and unit that goes on the wheel, but I'd rather not have to take the wheel and everything off if I don't have to.
      1979 XS1100 Special
        Unscrew the cable from the back of the speedo and zip tie it up so it doesn't fall down. Go for a little ride and see if that fixes it. It's probably your speedo gears themselves that are needing lubed.
        The fuel leak problems are from your float valves leaking more than likely.
        • 79XS11F
          • 3563
          • Ottawa, Ont. Canada
          Ya it could be the speedo drive unit or maybe even the cable in the sheath. Lube the cable and if that does not cure the noise repack the rive gear before it seizes up on ya.
          Rob
          KEEP THE RUBBER SIDE DOWN
          1978 XS1100E Modified
          1978 XS500E
          1979 XS1100F Restored
          1981 Suzuki GS1100
          1983 Suzuki GS750S Katana
          1983 Honda CB900 Custom
          • cywelchjr
            XS-XJ Super Guru(Deceased)
            • 4450
            • Sacramento, CA
            Not knowing if you have a standard or special (although it sounds like a special if it has an off position) sounds like the octo is not working/bypassed AND the needle valves in the carbs are leaking. IMNSHO you should fix both, which provides two layers of protection against this problem.
            • dbeardslee
              • 4385
              • Maineville, OH
              If it is your cable whining, you might want to lube it. This can be done by taking the cable loose at both ends. Take a plastic bag, make a hole in it, and twist-tie it to the cable such that the speedo end of the cable is inside the bag. Squirt enough WD40 into the bag to fully immerse the end in WD. Wire it up so that it stays in position and allow it to sit until WD starts to drip out the other end. Take the bag off, and reattach the cable ends. I use WD40 - not sure if this will work with cable-lube.
              • Korr
                • Jul 2008
                • 293
                • Torrance, CA
                That actually sounds like something that's been bugging me ever since i got my xs! I only notice it when i'm going 65 and up. It will get slightly louder the faster i go. Thanks for posting this question and and thanks for the replies guys! I'm will unhook it and test it out.
                1978 XS1100E Standard
                Tkat Fork Brace
                On Hold
                TopCat S.O.F.A. + Fuse Block
                Mike's XS Pod FIlters
                • cywelchjr
                  • 4450
                  • Sacramento, CA
                  Could it be the pillion whining for you to slow down?
                    • 7608
                    The other part that NEEDS lube now and then is the gears inside the speedo itself. DO NOT USE WD-40 as a cable lube, it will dry out, and the cable WILL break. Speedo cables need a graphite based lube that can be had at most auto parts stores. I use a silicon lube for the speedo, keeping the can up-right, and use the plastic straw to get the lube up into the bottom of the speedo housing.
                    • Ivan
                      • Jul 2008
                      • 2524
                      • Hutchinson KS
                      Easiest way to lube a speedo cable is to unscrew it from the head and pull the core out. Slather it down with some good lithium or moly grease and shove it back in. Takes about 5 minutes on an XS. On a car trying to do a headstand under the dash is a tad tougher. :P
                      FWIW, if you ever need to replace the speedo cable core, they are available at any parts house for less than 10 bucks. its a cut to length type of deal, same as on a car.
                      Ich habe dich nicht gefragt.
                        Hi Wolfpaws,
                        as has been said, detach the speedo drive cable. Lube it while it's apart.
                        Now check how easily the speedo turns. Shove a Robertson screwdriver into the speedo square drive and twirl it. There should be little or no resistance to motion. BTW, speedos from any XS series Yamaha will work. 120mph, 140 or 160 or even the metric ones from Canada will all read true.
                        • dbeardslee
                          • 4385
                          • Maineville, OH
                          Ray - You gave me quite a pucker on WD and speedo cable, and thanks Ivan and Fred for the info on getting the cable out - who knew? I didn't realize that cable would come all the way out. I tried pulling it from the bottom before with no luck - has to come out from the top on mine. Appreciate you boys putting us all on the right track.
                            For you... 2nd train track. Sit there and wait.
                            • dbeardslee
                              • 4385
                              • Maineville, OH
                              Dang Tod, have you been taking Prometheus lessons?
