So and idle mixture screwtip broke off in my number 1 carb, I had it drilled out by a machine shop and when I got it back it seemed everything was fine until i screwed another screw in and it only could go down about 6 turns (vs. about 9 turns on the other screws) I simply put it back together and wanted to check it out. It ran and idled on fully closed choke which it never did before which was awesome, except while trying to synch the barbs with the homemade vacuum synch the engine died and won't start, my brother says its prob running rich and fouling up the spark plugs so I am about to go get my new ones....
What can I do to compensate for that number one carb? and what is a good idle that I should be shooting for? I am a little confused right now...
...i did do the pre-synch...
...any help would be appreciated as I am out here right now!
