While rebuilding the fuel taps on my F today, I noticed that on the right side tap, within the vacuum diaphram cap there is a brass plug or restrictor that appears to be peened in place. That petcock works fairly well but not what I'd consider perfectly, even after renewing the seals and such.
When I took apart the left side, that brass plug fell out on the bench along with a small rubber washer. That brass plug appeared to be peened in at only one point and obviously it hadn't held. The other side had three peen points around the plug and it wouldn't come out at all. I put it back togther with the washer under the plug and peened a tiny bit of metal to hold it in place and it doesn't work well after the rebuild either ... continually dripping slightly ... a drop here and there ... Nuts !
The question is: Does that brass plug belong to be crimped into the vac. cap and does that washer go under the plug and next to the cap or what? There was no rubber washer evident in the right side at all ... so maybe it's underneath or just missing? Dunno. I have four different manuals and none show this figure well enough. There are 11 pages of 'fuel petcock' threads ...
Anyone know?
Anyone know?
) fell out in my hand along with this little washer exactly the same diameter. Doesn't seem like anyone's really had one of these apart.
....at least until I sit corrected again.
