For those who are contemplating the "2nd gear fix" for your XS or XJ, here is a quick parts reference list.
Part numbers for the 3 needed gaskets are:
2H7-15451-00-00 Gasket, Crankcase cover (Clutch side cover)
2H7-15461-00-00 Gasket, Crankcase cover 2 (shift shaft cover)
2H7-13414-00-00 Gasket, Strainer cover (oil pan)
Exhaust gaskets (4 needed) are:
431-14613-00-00 Gasket, exhaust pipe
Part numbers for the gears are:
2H7-17221-01-00 Gear, 2nd wheel (39T)
2H7-17251-00-00 Gear, 5th wheel (30T)
2nd gear washer part number is 90201-30398-00, but is no longer available from Yamaha.
In rare cases you may need shift forks:
2H7-18511-00-00 Shift fork 1
2H7-18512-00-00 Shift fork 2
2H7-18513-00-00 Shift fork 3
Forks are numbered left to right as you are sitting on the bike, so fork 3 is closest to the clutch.
While this list doesn't cover all the parts that might be needed in all cases, these are the most commonly needed parts.
You should read all the related articles on Ken Talbot's web page at:
http://www.rctvonline.net/xs11/
2nd gear...the saga continues....
