master cylinder
  • adleeman
    • Feb 2009
    • 47
    • lakeland, fl
    master cylinder
    rebuilt it once and no go.... so...questions
    spring has open end and plate end... plate end to cylinder open end to threads..? (so the fluid can get out? )
    rubber seal cup end to spring?
    thats how its shown. on my photo...
    if i put the plate end to the threads it blocks the hole
    cup between clyinder and springs... cup end to spring?
    am i missing any parts?
    Tony Leeman
    79 xs11 f, touring
    adleeman@yahoo.com
    Lakeland, FL
  • adleeman
    • Feb 2009
    • 47
    • lakeland, fl
    success maybe...
    its making a popping sucking sound when i pump it now...
    maybe i got something backwards the first time?
    Tony Leeman
    79 xs11 f, touring
    adleeman@yahoo.com
    Lakeland, FL
      • 7831
      Don't forget to "bench bleed" the master!! It will NOT work unless you do!
      With the master in a vise, between two blocks of wood, or something to hold it, add a little brake fluid, and with one finger on the port for the brake line, squeeze the brake handle all the way. You will have some air escape, but that is good. Keep the hole covered while you let go of the handle, and then repeat until you have brake fluid coming out, and cannot hold it with your finger.
      This will make bleeding on the bike MUCH easier.
        Goes together like this:
          Hi Ken,
          looks like the rightmost seal in the photo has to be forced over some pretty large diameter parts of the spindle to get to it's proper place.
          Any hints on how to get the seal into it's proper place without wrecking it?
            • 3193
            missing pics
            I think this post showed it but alas when i go to it the pics dont show up.
              Check out the tech tip again - I've just been in and fixed the imnage links.
                From what I can see, the inner cup is on backwards, and it will not generate any kind of pressure that way, except when you release the brake. Then it will force the fliud back into the reservior.
