idle mixture thread
  • Crazcnuk
    • Aug 2006
    • 2980
    • Hinton, AB, Canada
    idle mixture thread
    Just wondering if anyone has ever determined if the idle mixture screws are a standard thread of some type.
    I have two that chew up the idle mixture screwm and would like to chase them, if I can get a tap for it.
    '05 ST1300
  • red bandit
    • 957
    • central michigan
    6mm X .5mm IIRC it's not standard but it's common.
    79 SF parts bike.
      Not sure if it is the same on the BS34 type II and the type II that I have on my 81 or not. I know the screws mount up differently. The older type are exposed, the newer ones are down in the tunnel.
      When I got my stuck screw out, I took my old mixture screws (ordered new in my kits) and used them as a "tap" to chase the threads. Used Blaster as a cutting oil, and slowly worked it back and forth until I got the threads cleared. I counted the turns to see that I got it all the way down. Tarzan had a good suggestion of cutting grooves in the threads vertically to make a gap for the crud to go into, like a normal tap. HTH
      • Crazcnuk
        • Aug 2006
        • 2980
        That is what I did with the last set of carbs, too.
        However, with these, there seems to be a fair amount of aluuminum oxide in there, and I have wrecked the threads on two 'old' mixture screws, so far.
        The 80-81's use different screws than the 78-79.
        I was hoping the brass would be strong enough, but I guess not.
        '05 ST1300
          Not sure if this is the right size, but the tap is available.
          http://www.amazon.com/6mm-High-Speed.../dp/B0006FI7TU
            Update - found an old thread that confirmed the thread size for the later style carbs to be 6mm X .5 thread pitch.
            Sound liek you have the early types? Not sure on those.
            • Crazcnuk
              • Aug 2006
              • 2980
              No, I have the late ones, the ones down in the tube.
              Thanks for the info, I will try and find one of those!.
              '05 ST1300
                First reply has a link to one from Amazon, only $3.30 US. And it is in stock.
                • oseaghdha
                  • Aug 2006
                  • 1075
                  • N43.02.5,W88.14.2
                  This one is better.
                  Get you to the bottom.
                  XS1100SF
                  XS1100F
                  • corey
                    • Mar 2005
                    • 208
                    • Dexter, MO
                    $3.30 is cheap for that odd ball tap. I think I had to pay ten or so for the same rig when I fixed my chewed up threads.... that was before our economic mud slide, though...
                    Be sure to go slow... those are tiny tiny threads... :S
                    Corey J. Bennett
                    '79 XS1100SF
                    • Crazcnuk
                      • Aug 2006
                      • 2980
                      I only need it to clean threads in the aluminum housing, so not a problem if it isn't the highest quality.
                      '05 ST1300
                      • xs1100rider
                        • 62
                        • thornton,co
                        tap
                        craz, my offer still stands to mail mine out to you. i sent you a message about it yesterday.good luck with the threads. my wife is dragging me off to south dakota this afternnoon and i won't be back till monday.
                        79 xs11sf
                        80 xs11g-bagger
                        81 xs11g-project(trike/chop?)
                        80 xs400 special(wife's trainer)
                        • Crazcnuk
                          • Aug 2006
                          • 2980
                          Thanks, I tried to source one out locally, yesterday, including our local Machine shop, but no luck.
                          If I can't find one by Monday, I may have to take you up on your offer.
                          '05 ST1300
