Supplemental service manual
  • Crazcnuk
    • Aug 2006
    • 2980
    • Hinton, AB, Canada
    Hi there, I can't find my supp manual, but I seem to remember there was a change in it to the valve clearance specs for the 80 models?
    I have the valve cover off the special, to check the valves, and just want to double check what they should be set to.
    I also have to remember where I put my extra valve shims... bleh
    '05 ST1300
  • XSPastor
    • Oct 2007
    • 602
    • Gaithersburg, MD
    1980 valve clearances
    intake is .004 - .006 (.16 - .20mm)
    exhaust is .008 - .010 (.21 - .25mm)
    Tim Ripley - Gaithersburg, MD
    23mm float height
    120 main jets
    42.5 pilot jets
    drilled stock airbox with K&N
    Jardine 4 to 1 Exhaust
    spade fusebox
    1st and 2nd gear fix
    • Crazcnuk
      • Aug 2006
      • 2980
      Thanks, is that the regular settings or the revised ones?
      '05 ST1300
      • tinman905
        • Aug 2007
        • 946
        • Orangeville,Ontario ,Canada
        The intake was changed for 1980 to .004-.006 which you have is correct but it should read ( 0.11-0.15mm ) instead of "(.16-.20mm)" according to the the Yamaha supplementary and Chylmer's manual.
        BDF Special
        • XSPastor
          • Oct 2007
          • 602
          • Gaithersburg, MD
          Yup!
          You're right - I copied it incorrectly! Oops. Thanks for the correction!
          23mm float height
          120 main jets
          42.5 pilot jets
          spade fusebox
          • randy
            • Dec 2003
            • 4521
            Checking my manuals and my supp manual for the G and SG models shows a change in cams for the 80 models. The G and SG intake cam has .03mm LESS lift than the E and F models. Is that the reason behind the clearance change? Is it OK to use the tighter clearances on the older cams? Anyone done that?
              Randy,
              The Clymers manual suggest that you not use the tighter clearances on the older models. No explanation why though.
              • tinman905
                • Aug 2007
                • 946
                I the supplementary manual it just states " to reduce engine noise"
                BDF Special
