Kill switch questions.
  • excessive1100
    • 31
    All right, finally got the bike to fire up but with a couple of problems .
    I am getting no power to the starter solenoid. If I jumper the red/white wire coming from the fuse panel to the one red/wire from the right handle bar switch I can use the starter and start the bike.
    The kill switch will not shut the bike off, all it does is turn the neutral light on/off on the gauge panel. With the jumper wire in place the bike will shut off using the ignition swith.
    I am leaning towards both problems being connected.
    Any ideas ?
    Thanks in advance.
    1978 XS1100 Standard
    Hey there Excessive,
    First of all, it would be helpful for in the future to put the Year/Make of your machine in your Signature so that we wouldn't have to go and look at your PROFILE to see it, tech advice IS often model/year specific.
    Okay, looking at your Profile, I see you have a 78E! But now you have confused me with your wires? You say Red wire from right handlebar switch? There should be 1 red/yellow and 2 red/white wires, but no solid red wire...according to the wiring diagram.
    The starter button wire...Blue/white is merely a GROUND for the starer solenoid switch, low power side, it just completes the circuit to energize the magnet which throws the solenoid which switches the HIGH POWER switch to power the starter motor as well as the bikes electrics.
    The 1 solid red wire is both a tap off of the main starter cable, as well as going to the MAIN IGNITION/KEY Switch!
    There is a red/white wire at the starter solenoid, it's the low power side of the starter switch/button circuit, the blue/white wire at the handlebar completes that circuit to ground. A way to test the solenoid is to take a jumper and connect it to where the blue/white wire connects at the solenoid, and connect it to ground, IF the starter spins and bike starts, then the starter button or wire to that point is faulty, not contacting inside the button switch, or not grounding to the bars effectively.
    So..anyways, if you can provide some more clarification on what wires you are jumping, we can try to figure this out!?
    • excessive1100
      • 31
      yes you are right the wire is red/yellow.
      I have to jump from the red/yellow to the red white to get the starter to turn.
      The blue white at the starter button is fine that has been tested. The problem is that the solenoid wasn't getting anything from the red/white that connects to it and that is why I jumped from the red/yellow.
      What color should the wires be that go to the kill switch ? I am assuming that this is what is marked as the "Emergency Stop Switch" on the wiring diagram. I see them as being white/black and solid black. White/black goes to the ignitor and the solid black goes to ground.
      • XSPastor
        • Oct 2007
        • 602
        • Gaithersburg, MD
        Listening excessive1100?
        Did you see this part of TC's post? This can make the difference between the right advice and the wrong advice or sometimes whether you get any help at all. Do it.
        Tim Ripley - Gaithersburg, MD
        23mm float height
        120 main jets
        42.5 pilot jets
        drilled stock airbox with K&N
        Jardine 4 to 1 Exhaust
        spade fusebox
        1st and 2nd gear fix
        • excessive1100
          • 31
          Thought I already did that, back to the User CP to try again.
          Well I see that it is working now.
          • XSPastor
            • Oct 2007
            • 602
            • Gaithersburg, MD
            I see it now!
            Nice. That wasn't so hard, huh?
            23mm float height
            120 main jets
            42.5 pilot jets
            spade fusebox
              • 8766
              The emergency stop switch in the diagram is the tip-over switch under the fuel tank. The kill switch is the right handlebar switch. Should be red/wht.
              • excessive1100
                • 31
                I figured that out from the wire diagram after I am made the post but I couldn't go back and edit so I wouldn't look silly.
                • excessive1100
                  • 31
                  I figured I would head out to the garage and trace some wires with the multimeter.
                  Turns out that I created the problem, when I installed the TopCat fuse block. I mixed up a couple of the brown wires. Had all of the brown wires on the power side of the block. When you look at the diagram one of the brown wires is supposed to be on the opposite side .
                  I hope this makes sense. Anyways it is fixed. I guess it makes sense to double check what you did prior if something stops working.
                    Yep the sequence goes...Worked fine..I di%^ed with somethin'...It aint workin so good....What did I do??....Trace back through....Ohhhhhh shi*....BTDT many a time.
                      And by the way, next time you have a question like this after dorking wiht something like replacing the fuse box, PLEASE MENTION IT IN YOUR QUESTION!!
                      That would have sent alarm bells to all of the really smart folks here that offered you suggestions to have you check that first and saved you and them alot of time diggin through other stuff.
                      • excessive1100
                        • 31
                        Actually not posting the problem on the forum at all would have saved me alot of time.
                        Instead of waiting for someone else to post info to solve the problem I should have started investigating right away.
                          Dont take that the wrong way. Only stupid question is the one not asked. Look at my history for proof of that!
                          Just sayin, that was kinda important info for lookin at an electrical gremlin type of problem.
                          • excessive1100
                            • 31
                            I wasn't taking it the wrong way. If I had checked all the basics I wouldn't have had to post to the forum for help. I would have solved it myself or at least narrowed it down.
                              • 7737
                              Sometimes just "posting" will wake up the gray matter! We've ALL BTDT, and don't listen to Prom when he says something else!
