I've been having all sorts of dramas getting my recently (almost) complete project bike to sustain a decent idle. Seems to be fighting me all the way. Thing is, I'm getting spark on all 4 cylinders, no leaking fuel back into the airbox, and it runs, but it will tend to rise in rpm and not come back down for ages (if at all) if the idle is adjusted to around 1100rpm or so. But if the idle is lowered to bring it back again, it stalls out. The idle is extremely uneven, yet I'm not getting the problem with a cold header upon starting.
As far as I can tell, it sounds like a vacuum leak problem, but I spose it could also be the pilot circuit with crud in it. Mind you, I've done the trusty clean x 3 trick, and it just doesnt seem to be making a difference. I also need to give it a better sync than a bench sync with a kitchen tie, I reckon, but I'm without a vacuum gauge or mercury manometers.
One thing I did notice though, is the idle mixture screws are a bit of a strange shape on the end. Sorta deformed from overtightening if you ask me. But would this cause the poor idle symptoms I'm getting? I got a shot of the mixture screws for all to take a gander at... (I'm hoping that link works, I couldnt get the photo to insert properly, I'm bit of a cluster with that sorta thing)
http://1.bp.blogspot.com/_GlFNi4L8c7...1600-h/059.jpg
They don't seem to be an even shape, and this photo doesn't really show the slight bend in the tips very well either. When lightly seating one of them, I reckon I can feel the tip entering the hole unevenly.
Any thoughts?
Any thoughts?
