Engine Clear coat
  • Engine Clear coat
    Is it possible that the clear coat on my engine covers is completely gone? How can I tell?
    It was finally warm enough outside today for my little portable heater to get my garage to the prerequisite 70 degrees. I turned off heater then I applied aircraft stripper wrapped it in a bag, waited a half hour and nothing. Not one bubble or blister and no sign of paint coming off when I cleaned off the stripper. I then repeated and the results were the same. I searched to see if there should be clear coat and per the thread below there should be. I really want to get the clear coat off today so that I can spend my layoff productively working on the bike, and the weather will not be this warm again for a while.
    http://www.xs11.com/forum/showthread...+clear+factory
    Dave
    1979 XS1100SF Special
    It is possible that it has aready been removed. Aircraft stripper would have peeled it off in a heartbeat. You can try some aluminum polish and see if it shines up, it won't do anything if the clear coat is still there. You could take a sharp blade and see if you could scrape any off from an unseen area like under the cover. I stripped the clearcoat form my covers and fork legs and polished em up with Simichrome (best stuff I have found). A mini Mothers Power Ball on a drill makes short work of this project. It takes a little more work to keep em clean and shiney but the job is a labor of love.
      Thanks for the reply and the advice I was thinking about doing the fork legs. I bet that they look sharp. I must say that I am surprised that the PO removed the clear coat. I can think of countless better ways he could have spent his time
      Dave
        Fork Legs
        The fork legs look really good after polishing. Here is a picture of my 78 after I polished the forks and restored wheels.
        78 XS1100E Standard
        Coca Cola Red
        Hooker Headers
        http://i408.photobucket.com/albums/p...m/DSC00580.jpg
        1979 XS1100 Special
        http://i408.photobucket.com/albums/p...m/DSC00612.jpg
        1980 XS Standard
        http://i408.photobucket.com/albums/p...m/DSC01137.jpg
        2006 Roadstar Warrior
        http://i408.photobucket.com/albums/p...um/warrior.jpg
          I really like the looks of the fork legs all polished up! You're bike looks stunning Did you clear coat the polished parts?
          Dave
            polished fork leg
            hi Dave,
            Just polished this one up this arvo,
            much easier 2 do off the bike, i also replaced the seal.
            ive never clear coated, doesnt take much to keep em lookin good.
            pete
            new owner of
            08 gen2 hayabusa
            former owner
            1981 xs1100 RH (aus) (5N5)
            zrx carbs
            18mm float height
            145 main jets
            38 pilots
              Dear Pete,
              I'm off tomorrow and Friday. If you have some free time let me know. I have dull everything.
              Dan.
              Automotive Imbecile.
              Proud owner of 'The Swiftcicle'. (Swifty for short)
              '78E Full Vetter Dresser.
              1196 Big Bore Kit.
                Your forks look great!
                I would be worried that if I took the forks off my bike I would thereafter have a unicycle. I can ride a unicycle, but I enjoy having 2 wheels on my motorcycle
                Dave
                  Clear coat?
                  I did not clear cloat. One you get it polished up, it only takes a little maintenance to keep it up.
                  78 XS1100E Standard
                  Coca Cola Red
                  Hooker Headers
                  1979 XS1100 Special
                  1980 XS Standard
                    Mothers!
                    This is inspirational.... do the mothers PowerBalls work that good? I think of all the time I've spent polishing... and if the ball does it quick and that good, I'm all over it.
                    Corey J. Bennett
                    '79 XS1100SF
