1979 XS11, 12k miles on it, I've had it for almost a year now.
This past weekend, I finally got around to changing the gear oil. Also, I tried to change the air filter, but the dang thing got twisted up in the cotter pin which holds the wing bolt to the air box. Took me an hour to get it off (which included a LOT of swearing and banging). Also topped off the engine oil; it was a bit low.
Anyway, all seemed to go well, finally. The gear oil is a little bit high in both, but not much, and the old air filter is back on.
However, when I started it up a few mornings later, the oil light stayed on. It ran fine, but I shut it off after a minute or two in fear of no lubrication.
I can't imagine what I would have done to cause the oil pressure to go south. I thought the cause was most likely electrical as I was banging around the air box a lot in my efforts to get it off; perhaps I knocked out a wire? However, I looked tonight and didn't see any obviously loose wires. Also, I replaced the brake light bulb in case that had gone bad (even though all lights were working normally).
I'm not sure where the pressure gauge is wired from and to - can anyone clue me there? Any ways to eliminate this as a problem?
When I ran it tonight, the engine did sound a bit rough, and one of the cylinders was coming in and out. However, I never let it get warmed up, so it's hard to say if it really is sounding abnormal. I am extremely worried.
The light stays on constantly, even whilst jiggling various wires, and I've never had it come on before now, so I don't suspect a bad tail light ground or anything like that.
I saw in this thread that someone bought a relatively cheap oil pressure gauge. I'm wondering where this goes. Where does it install??
Any suggestions for how to proceed? I'm thinking either change the oil/filter (maybe gunk in the filter - but I did change it less than a year ago; it's probably due but it certainly shouldn't cause any problem like this, methinks).
Maybe if an oil pressure gauge is cheap and easily installed, that's worth a go.
help please
