Been a while since I posted here. I missed you guys too! *hugs*
Anyway... :S
So I synced my carbs with a custom sync tool... THE BEST $7 I HAVE SPENT. Turns out having syncrhonized carbs is a key aspect on 4-cyl bikes...
Thing runs like its new out of the box, hardly needs the choke on start up even.
However, I still have a problem which I first noticed late in the fall. Bike starts fine, no issues with ridability (i.e. no missing, hesitation, loads of power). I can ride it to work (~7 miles, enough to warm it up) and turn it off and restart it with the starter with no problem. However, if I ride it for more than, say, 25 minutes the thing will not restart for anything save bump starting. If I go for a cruise on the highway, backroads, or a long jaunt around town it just won't start. After bump starting, however, the thing backfires through the pipes loudly once and then runs like a champ... by not starting, I mean that the starter turns the motor with no problem (I feel compression out the exhaust) at a good tempo... it just won't hit.
Any ideas? Anyone else ever have this problem? I plan on doing some voltage test at the battery to make sure the starters not starving the coils of voltage at warm startup.... and I will check for spark next time the problem occurs. For now though I'm fishing for "easy answers"... if those even exist...
Thanks, its good to hear from you all again.
Anyway... :S
Thing runs like its new out of the box, hardly needs the choke on start up even. However, I still have a problem which I first noticed late in the fall. Bike starts fine, no issues with ridability (i.e. no missing, hesitation, loads of power). I can ride it to work (~7 miles, enough to warm it up) and turn it off and restart it with the starter with no problem. However, if I ride it for more than, say, 25 minutes the thing will not restart for anything save bump starting. If I go for a cruise on the highway, backroads, or a long jaunt around town it just won't start. After bump starting, however, the thing backfires through the pipes loudly once and then runs like a champ... by not starting, I mean that the starter turns the motor with no problem (I feel compression out the exhaust) at a good tempo... it just won't hit.
