Im curious to know what the inside of a CDI box contains, and if it can be taken apart and cleaned up, like how I opened up my kill switch and cleaned off the corrosion by grinding on all the small metal parts with a wire wheel brush.
What is inside a CDI box?
That's a tough one. Some would say that the devil himself is in that little black box. Others have opened it only to do more harm than good. There is really only one thing the layman can do in there, explained on my website. Click on my handle and visit my website. Good luck.
BTW, if it's working, leave it alone. -
If you open it... the magic leaks out.
Like Randy said... if nothing's wrong... then there's nothing in there worth dickin' with. Just a bunch of resisters, transisters, twisted sisters and other stuff that normal people don't understand.
(Randy knows, though... he's sort of geeky that way.)
Your bike is sparking on all four cylinders... nothing's wrong."Damn it Jim, I'm a doctor, not a mechanic!' ('Bones' McCoy)Comment
Thats an easy answer, theres smoke in em. You can't buy that kind of smoke anymore but Randy makes it and puts it back in.When a 10 isn't enough, get a 11. 80g HardbaggerComment
Webbcraft... are you trying to put mechanics everywhere out of work?
Putting the smoke back into a machine is a secret that mechanics share amongst themselves... and is not to be shared with the general public.
But, seeing how you've already violated that sacred trust... and I'm now getting thousands of PM's, "Hey Prom, tell me the secret of the Magic Smoke Webbcraft wrote about....", we might as well share the knowledge.
Gurus and mechanics all know about smoke.
Smoke is what makes machines work. The engine runs on smoke... the electrical system only works because of the smoke contained in the wires, etc.
An easy to understand example would be an electrical problem... like a wire pinched next to the frame. Once the bare metal frame rubs the insulation off the wire... the smoke starts to escape. Anytime that you see parts of your wiring harness smoking, you can be assured that you will soon have an electrical failure due to the lack of enough smoke in the system to keep it functioning properly.
Webbcraft is correct. It's very hard to find that kind of smoke anymore on the open market.. sort of like freon for air conditioners.
Randy knows the secret recipe... but must charge a small fee, due to the rising cost of materials."Damn it Jim, I'm a doctor, not a mechanic!' ('Bones' McCoy)Comment
It has retroencabulators. Yamaha was working with Rockwell automation in developing this new ignition system.
This should explain it all, very clearly.Ich habe dich nicht gefragt.Comment
Ahhhh... Pretty impressive to explain it all in Lehman's terms like that. The ol' differential gurgle spring... can't work without that!
I heard that as "differential girdle spring". BTW the spring one sees backing up the sealing lip of a rotating shaft oil seal IS a girdle spring (aka garter spring) and doesn't the average differential have some of those?
"From BS, truth and from truth, BS"?Fred Hill, S'toon
"The Flying Pumpkin"Comment
Once you understand the theory, practice becomes elementary.Ich habe dich nicht gefragt.Comment
