trans question
  • kelliott
    • 7
    trans question
    Just put in a new trans is there a break in time for it and if so how long
  • TADracer
    • 1417
    • Kenner, Louisiana USA
    Thats a good question. I would think there is not really any break in period if you only changed the trans since most of the movement is rotating and not linear like say, a piston in a cylinder. At least not any break in period like you would have if you installed new piston rings or something like that.
    Still, I might take it easy for a few miles varying my speed until I know everything is right.
    Not based on any fact, only my thoughts.
    Mike Giroir
    79 XS-1100 Special
      SO what exactly do you mean by "New transmission"?
      Did you replace everything new, or used stuff? What all did you do?
        Break in
        Yep, I agree. When I do a trand rebuild, I tend to take it a little easy for a short while just to make sure things are shifting properly, then I let her rip. Doesn't hurt to do an early oil change, just to make sure of no left over contaminents. JMHO
        • kelliott
          • 7
          New trans gear middle gear shift drum shift forks the shift fork rod new clutch assly new plates and all new bearings for anything that was in the open
