If the bike was running fine carb-wise with a stock motor, then you had it bored and put in the 1196 kit, would the carbs need re-jetting?
One train of thought says that the air/fuel mix the carbs are sending into the cylinder hasn't changed.. just a bit higher amount of it with the big bore.. and wouldn't need to change anything on the jets.
The other train wonders if it is going to be the same amount of fuel with a higher volume of air and leaning it out. BUT with the way a carb works.. air drawing the fuel.. more air would mean more fuel also.
I changed the jetting on mine for the pod filters a little bit, but I never changed anything after the 1179 kit. Has anyone that's done the bigger bore had any problems and need to re-jet the carbs? Not that it really matters, but the project is going to be done to an XJ.
but I made a typo on the jet sizes and it's the center two cylinders on the Standard that gets the 120 jets and the outer two get 115's. You gotta be on your toes on Channel Eleven lest someone will nail you on a mistake. Damn, I hate it when that happens to me!
