Is a missing fuse block a problem?
  • LCS249
    • Oct 2007
    • 232
    • Albuquerque, NM
    I've had my bike for just over a year now and it has not been an issue, since fuses are in-line on individual wires.
    But a new friend who's far more mechanically inclined than I am looked a little shocked at the empty space behind the right-side side cover on my 1982 XJ11.
    Should I worry?
    1982 XJ1100J Maxim
    2000 BMW R1200C
    “We go to heaven for the climate, hell for the company.” – Mark Twain
  • egsols
    • Jan 2006
    • 1090
    • Barrie, Ontario, Canada
    If all of the correct ciruits are protected by the correct size of fuse then it shouldn't pose a problem. If they aren't then it is time to worry.
    To be on the safe side it wouldn't be a bad idea to check a wiring diagram to make sure that all the circuits are adequately protected.
    If the wires haven't been hacked too bad then wiring in a fuse block isn't that hard a job and it certainly makes life easier to check fuses, plus it gives a stable mount for the wiring.
    Ernie
      • 8863
      fuse panel
      It shouldn't really matter as long as everything is wired properly. It just doesn't look as neat. The function ability should be the same.
      • Ivan
        • Jul 2008
        • 2524
        • Hutchinson KS
        TC has nifty fuse blocks for sale.
        Ich habe dich nicht gefragt.
          With the fuse block GONE, it shouldn't pose a problem, but on the XJ with a stock fuse block and/or backing plate in place, there's not enough room for these fuse blocks TC sells to attach to the backing plate and fit under the sidecovers like the XS does.
          Mine doesn't look nearly as nice, but I attached some female ends to the wires, heat shrinked over the metal end, and plugged the spade type buss fuses into those.. then tucked them under the sidecover. It was just my preference to get away from the old glass fuses.
          • Wretched XS
            • 12
            • waterloo new York
            Son did it and it worked.
            My son Henri has an XJ and because one of the connectors broke replaced it with an inline fuse. Long story short he ended up replacing all of them and its workwed fine. no problems at all.
              TC's fuseblock in an XJ!
              It took me a little while to find the thread where I had helped BNE with MadMax-im this summer, and we fitted the fuseblock into his XJ, but it took some modifications of the metal mounting plate, trying to retain the OEM AUX fuse terminals. See below for details, but it will fit and the side cover will close with some form of modification. Yes, it's not plug and play!
              I decided to inspect the wiring at the fuseblock....a good foundation right!!
              Being an XJ, the fuseblock I offer/sell doesn't fit horizontally on the TOP/outside of the OLD block/plate, hits the side cover preventing it from closing!! There's also a metal mounting/battery frame that the plate screws into, and so the wire connectors would be hitting it IF mounted horizontally behind the OEM plate, even with cutting an opening.
              I finally got the idea to mount it vertically, I could have lopped off the plate at the purple lines. I used one of the 3 screws for the Aux. Term and screwed it in from behind securing the fuseblock to the plate that way, cutting off the other mounting hole/flange off of the fuseblock so it wouldn't hit the frame!!
              Here it is mounted on the bike all the wires run, but haven't put the fuses or cover on yet! I even rerouted the AUX terminal thru the fuseblock so he could still have the use, but with the ATCO fuses!!
              Another point of problematic grounds that we talk alot about it this one, the engine to frame above the middle drive!!
              • Ivan
                • Jul 2008
                • 2524
                • Hutchinson KS
                I wonder about using an ATX fuse block, Which would be the very small spade fuses, but still shaped like the ATC. I think that might be the ticket on an XJ.
                • LCS249
                  • Oct 2007
                  • 232
                  • Albuquerque, NM
                  This is getting way more "interesting" and a tad more complicated than I anticipated.
                  TC, what's the "issue" with the ground over the middle drive?
                  Best,
                  Leon
                  1982 XJ1100J Maxim
                  2000 BMW R1200C
                    Look at the condition of the screw and the connection. That amount of corrosion will not provide a "good" ground. I believe TC ment to point out the need to clean that up to re-establish a good ground.
                    • COOL TOM
                      • Jul 2005
                      • 288
                      • CANTON, IL
                      Fuse Block
                      My son and I put 2 of TC's fuse blocks on both of our XJ's. Had do do minor adjustment to get them to fit, but nothing major. Did not have to alter the side covers. We did not use the old fuse block plate. Also have put them on the 78E XS and 80 special,really like those fuse blocks TC.
                      Thanks Tom
                      82 XJ DAILY RIDE
                      78 XS1100E FIXING UP
                      79 XS1100F PARTS BIKE
                      79 XS1100SF NAKED BIKE
                      80 XS1100SG FULL DRESS BIKE
                      82 XJ IN THE ROUGH
                        Come on Ivan,
                        You know most of us shadetree mechs have meathooks for hands/fingers, and so I don't know if I could hold onto an itty bitty ATX fuse!!
                        Hey CoolTom, how about a few photos of your XJ's and the way you rigged the fuseblocks into them??
                        Yeah, clean those grounds!!
                        • Ivan
                          • Jul 2008
                          • 2524
                          • Hutchinson KS
                            • 6762
                            Kat those pics are from the famous TC Tech days I had last Aug at TC's home.While that is a fuse block on my XJ...I dont think its the same fuse block TC has forsale. He made those mods on the fly...so to say...BTW it should be noted that the fuse block on MadMax is somewhat protruding out thus making it a very tight fit with the side cover. In fact I have to press the side cover in a bit to get it to line up with the screw hole. But everything work fine
                              • 6762
                              Arrrrgh Bad Coffee
                              I dunno why I thought KAT originated this thread...I didnt sleep in a Holiday Inn last nite
