I think I know but....
  • I think I know but....
    I had to pull my carbs back off today, another stuck float needle. Really got to get the in line filters and new fuel lines on now, been trying to get it worked out but need more fuel line to make it work. Anyway, as I pulled the crankcase vent off of the air box, I got a white curdled milk looking goo out of it. Was at the top and bottom of the hose. Hose was not plugged completely.
    My thought is that I have been messin with the bike and starting it and letting it idle up but not quite warm all the way up or riding at allm xhexking if I had duel flow to the carbs due to changing routs for filter install. Thinking that moisture has been condensing in the vent tube and mixing with the oil in it to create the goo.
    Seem right? Am I overlooking an indication of a problem? Oil in the crankcase does not have any of this in it from what I see looking in the fill hole. And the oil has less than 150 miles on it.
    Thanks for any thoughts.
    Yep.
    More apparent this time of year.
    You can see it on the oil fill of your car too.
    XS1100SF
    XS1100F
      My father was an aerial sprayer, and is now a bush pilot in Alaska. Having over 10k hours on air cooled engines, I guess he knows what he is talking about.
      To the point. My dad will never start an aircraft engine without bringing the oil temp to operating temp. He says that getting the temperature up evaporates the water out of the engine oil that condenses in it while it sits. He is very picky about his engines, but his engines last forever, since he maintains and operates them effectively.
      Something I found interesting about flying in Alaska. When setting up for a landing, pilots of reciprocal engines, can't just yank the throttle, since it will cool the engine unevenly and possibly break things due to thermal contraction. I guess -50º air is pretty good at cooling. So think about that the next time you ride in -50º temps. Might save you an engine.
      Ich habe dich nicht gefragt.
        Flew to Shanghai yesterday.
        While going over Canada, the outside temp read -75! I know that was at 30K' AGL, but dayum, that's COLD! I don't care who you are.
        XS1100SF
        XS1100F
          The duel is easy to figure out. Many people use it instead of the correct spelling dual. But I have no idea what you were going for here:
          allm xhexking
          Little help?
          Tim Ripley - Gaithersburg, MD
          23mm float height
          120 main jets
          42.5 pilot jets
          drilled stock airbox with K&N
          Jardine 4 to 1 Exhaust
          spade fusebox
          1st and 2nd gear fix
            Pastor, That is called fingers not connected to the brain for a moment.
            Should have read "....or riding at all, checking if I had FUEL flow to the carbs...."
            I read that yesteday and just shook my own head at myself.
              Mine stay connected to the brain... they are just way too fat sometimes! lol.
                Ha! I'm familiar with that feeling myself!
                23mm float height
                120 main jets
                42.5 pilot jets
                spade fusebox
                  Retaining water again?
                    By now... you KNOW that if a person who is in fact retaining water.. that is one thing you DON'T ask. Why not just.. "Honey, this Midol will help you not be so bit@hy.."
                    But in my case.. no.. not retaining water. Just retaining the holiday meals.
                      "Talk about bloat..."
                      Geez... I've put on twenty pounds since you saw me in June, TRBIG.
                      (You and I could be twins... though I'm the better looking one)
                      Went food shoppin' with my brother today.
                      I commented on the 'large' lady in the aisle up ahead...
                      My brother said, " Ya know... from the rear, she looks like you, from the front!"
                      Diet starts soon... (yeah, just after I quit smokin', right?)
                        You can always hope it will help...
                        81 SH Something Special
                        79 SF MEAUQABEAUXS
                        81SH Nor'eas tah (Old Red)
                        80 LG Black Magic
                        78 E Standard Practice
                        James 3:17
                        “Alis Volat Propriis”
                        Yamaha XS 1100 Classic
                        For those on FB
