carb hookup
  • screamin deal
    • 73
    • vacaville,calif.
    carb hookup
    at the risk of sounding real dumb, ok I am not a mechanic, Hooking up my fuel lines, on the carbs, upper tee's vent lower tee's fuel? I am pretty sure but it has been awhile since I took it apart, now I can't be sure putting it back together.
    Screamindeal
    1979xs1100sf
  • prometheus578
    XS-XJ Super Guru (RESIGNED)
    • Aug 2004
    • 4012
    • Olympia , Wa.
    "It's "T" time."
    Correct.
    Upper Tees vents, lower Tees fuel.
    Vacuum line from the vacuum advance unit goes to the port on #2 carb,
    • screamin deal
      • 73
      • vacaville,calif.
      cool
      alrighty then back to the man cave, I am determined to giter done today. Now I will need to run back to auto parts store to find breather filter for these lines.
      Screamindeal
      1979xs1100sf
      • screamin deal
        • 73
        • vacaville,calif.
        bike running
        Yaahoooo The old girl fired right up and sounded pretty darn good. I still have a few minor details like breather filters and my gasket on my oil filter cover did not seat correctly so it is leaking. I had intended on just idling for a while and changing the oil again as a flush because the oil I changed out was the gassy stuff. So now I have to anyway. When she runs with no leaks I am going to take it to my mechanic and have him sync the carbs then I should be ready to roll the next time the streets are dry.
        Thank all of you for all your help and advice.
        Screamindeal
        1979xs1100sf
        • thewiz
          • Oct 2006
          • 1115
          • Wilksboro, NC
          Be careful ...
          not to overtighten the oil filter cover bolt. That cover can crack pretty easily ... there are some o rings in the bolt/cover assy so be sure they are there and correctly seated .... you have a manual, right?
          80G Mini-bagger
          Past XS11s
          • screamin deal
            • 73
            • vacaville,calif.
            Yep I have a manual, the o ring slipped out in one spot hence the leak . I will try to get to it today but my boss has some crown moulding she says is calling my name. I see a tow truck coming to pull me out of my man cave.
            Screamindeal
            1979xs1100sf
            • Ivan
              • Jul 2008
              • 2524
              • Hutchinson KS
              Ugh, crown moulding. I really hate that stuff. To me it looks gaudy.
              Your penance shall be to baptize thy self in gear oil (sprinkling is ok, unless you really feel the need for full immersion), and ride around the block three times with open headers screaming "Hail Mary!!!"
              Ich habe dich nicht gefragt.
              • prometheus578
                • Aug 2004
                • 4012
                • Olympia , Wa.
                Crown moulding is cool.
                Adds a touch of class (not that I need any) for a relatively low price.
                If only they made "wavy" crown moulding, to match the wavy parts of my ceiling.
                • screamin deal
                  • 73
                  • vacaville,calif.
                  Looky,Looky,Looky
                  tried sending a pic of the finnished product but could not get it out of my kodak easy share. And yes I did take her for a spin and got the crown done.
                  Screamindeal
                  1979xs1100sf
                    So I take it the SEG is firmly planted on your face??
                    • screamin deal
                      • 73
                      • vacaville,calif.
                      looky,looky,looky
                      [IMG][/IMG]
                      Screamindeal
                      1979xs1100sf
                      • screamin deal
                        • 73
                        • vacaville,calif.
                        She ran ok for my test run still a little popping can't decide if I should jet up or just get carbs synced and see what happens. I assume popping means too much air so the direct mount of my pods is not restricting flow. Any advice?
                        Screamindeal
                        1979xs1100sf
                          I would get the carbs synched FIRST, and then go on to rejet as needed. If it's popping as you slow down, a little bit of a turn on the mixture screws may fix it.
                            I would synch the carbs, definately. This should be done before final adjustments with mixture screws (pilot screws). If you have a non-stock exhaust ststem and it pops a little on deceleration, IMHO you should expect this to possibly happen, even if you have the carbs optimized. No big deal. Tune the carbs for wide open throttle (or at least no fade at high speed), mid range without dead spots in the range, and idle conditions up to 3000 rpms. Don't sweat the small stuff. Don't worry, be happy.
                            • theduke
                              • Dec 2008
                              • 38
                              • Oklahoma City
                              Originally posted by prometheus578
                              Correct.
                              pardon another rookie question, but the vents should go...? doubtful their meant to be left to the open air, which is the case on mine right now
                              79xs11f - ugly as sin after sitting in a garage for 12 years, but rumbles like the beast that it is.
