Another pod filter question.
  • bigray03
    • Sep 2008
    • 152
    • South-Central Lousiana
    I am putting pods on keeping stock exhaust. Do I need to change any carb jets and if so which ones and what size?
    80special w/79special motor.Never ride faster than your angel can fly!!
    You may not have to change jets, depending on what the plugs look like, and how it runs. Usually, if you turn the mixture screw out about 1 turn, the bottom end will be ok. The big test will be any stumbles or problems as you transition, 3K to 3.5K RPM. You will also need to test at WOT, to verify you can flow the fuel needed through the mains. If you are a little lean, one size up on the main jet will usually do the trick.
