powder coating forks
  • Texas Rookie
    • 63
    Ok DSXS, now you've done it. I get all fired up to get the forks powder coated and start taking them apart. Fluid, we don't need no stinking fluid, is everywhere (was going to change that anyway), I just thought I had drained it all (didn't realize how much fluid those springs hold). And everytime you bump/pump the fork a bit....out comes more through those drain holes (which provide great velocity by the way!)
    Stripped one of the studs that holds the axle pinch cap (going to need one of those and a new nut).
    Anyway, caps off, springs out....now how do you get the tubes and seals out? twisted the allen screw on the bottom and what ever is inside just spins........ and spins......... and spins.
    All assistance is appreciated.
    Anyway, had asked in "details" thread if anyone had experience with home powder coating kits. would like feedback on whether this is a viable option or not. Thanks again.
    Also was looking at ss brake lines on mikesxs but not sure about the rotated fitting business and all these parts are for 650's. Are some interchangeable?
    Texas Rookie - NW Houston
    79 xs11F (in process, down but not out)
    04 Ducati ST4s (current daily driver, recently retired from occasional track bike duty, too $cary to think about crashing)
    2001 Suzuki SV650 track bike (setting up for some adult fun next year)
    newest acquisition - Black on Black 78 XS11 with 81 motor waiting patiently in Cleveland Ohio (Insanity!!!...no thanks I've got plenty)
  • selfmade
    • 54
    home pc is ok but remember the learning curve. if you mess up it is a lot of stripping and clean up of the pc to do it again.
    • Dsxs11
      • Jun 2007
      • 240
      • Millington, Michigan
      I'll retype my orginal post that got deleted.
      But that's a great kit above and it's on sale for 142.00 comes with everything but air and and oven.
      I hate signatures. Too many cars and Bikes to list here.
        • 8930
        You can make a tool like this with a 3/4" bolt and 2 3/4" nuts. Slip it down the fork tube and turn it with a deep socket and long extension. The bolt head fits into the damping rod and'll keep it from spinning. Pry the seals out with a seal remover tool.
          • 8930
          bolt
          Meant to say a 1/2" bolt with a 3/4" size head.
