Not getting any input from "other bike" forum so ...
  • 79XS11F
    • Jul 2006
    • 3563
    • Ottawa, Ont. Canada
    Does anyone know if a 150/80-16 rear tire can be used on the CHAIN driven 650 Special with the 16 inch rear wheel . Would the tire allow enough clearance between the chain and the tire's wider profile.
    I need to know as I am about to buy tires for my chain driven XS1100 project bike that makes use of a 16 inch 650 rear wheel with a stock sprocket and i would like to use the fattest tire I can.
    Thanks
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
  • Korr
    • Jul 2008
    • 293
    • Torrance, CA
    Check with DiverRay. I can't remember what size tire he used for the rear of his midnight special, but he only had about a 1/4 inch gap left on the drive shaft side. He didn't have to modify anything i don't think.
    1978 XS1100E Standard
    Tkat Fork Brace
    On Hold
    TopCat S.O.F.A. + Fuse Block
    Mike's XS Pod FIlters
      • 7766
      I put a 140/90 16 on the rear of the Midnight. I do NOT have 1/4", I have about 0.050" The 150/80 16 SHOULD work well.
      • xschop
        • Feb 2006
        • 1794
        • oklahoma city
        650 chain
        I have seen a couple stock 650's and it looks like there is a good 20-30mm clearance betwwen stock chain and tire at the rear. Are you using the alloy 650 rim or the spoked? Because if spoked, then you can relace it with a wider alloy rim and stick on a 170-180 rear tire. The custom chaindrive unit's sprocket is designed to adjust laterally and the rear sprocket is a No-brainer with the same width spacer/s installed.....Chop
        MDRNF
        79F.....Not Stock
        • xschop
          • Feb 2006
          • 1794
          • oklahoma city
          updates
          I just checked out your Hop-up bike, That is going to be a cool looking bike. I saw that you hadn't notched the frame yet. You may not need to if only going with a 150 series rear tire....Our Aussie friend had a 180 on his with just a plastic down-tube guard on his lower frame. I went 200 so I definitely had to notch it !!!!AFTER WELDING IN THE BRACE!!!! DO NOT NOTCH THEN WELD!!!! you could distort the pivot area.....Chop
          MDRNF
          79F.....Not Stock
